Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 01-26-2021, 05:22 AM
timtech timtech is offline
Default Sound Card
I am currently trying to get an up to date spec for a Pro-Tools Windows 10 PC.
Firstly, what kind of sound card would I need? I will be using an external sound module eg a focusrite scarlett (or something similar), but what sound card would I need.
Old 01-26-2021, 06:53 AM
sw rec sw rec is offline
Default Re: Sound Card
Onboard sound (typically a Realtek) should be just fine for non-Pro Tools audio.
Old 01-27-2021, 08:47 AM
Thanks - so would e.g a soundblaster card be ok - in other words Pro Tools doesn't use the PC's sound card(?). But what do you need, then, in order for the Focusrite external module to be connected to Pro Tools? Do you have to have a special card - or is it just an ordinary USB port?
Also - is there some software which has to be installed and which runs on the PC to make the Focusrite module work?
Old 01-27-2021, 10:08 AM
TOM@METRO's Avatar
Have you checked the Focusrite website?
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 01-27-2021, 10:11 AM
Focusrite does make USB interfaces, so one of those will connect to any USB2 or USB3 port. If the motherboard has an on-board sound card(Realtek, as mentioned is common), then you don't need a SoundBlaster, but if you WANT to buy one for Windows audio, that's fine(but I would not waste the money). The idea is to let Windows have its own sound card, so that Pro Tools will have exclusive control of your recording interface.
You will need to install the Windows ASIO driver for whatever interface you get(drivers are provided by the maker of the interface). When you first install this driver, Windows will usually grab it as the default playback device, and you will need to reset that back to the on-board(or Soundblaster) sound card. Sometimes, a Windows update will change some settings(without telling you), so remember to check the Windows sound settings if you have any problems. Another setting that sometimes gets changed is turning off the Power Management feature on all USB ports(a tweak you need to perform).
How do i make my digidesign sound card my dedicated sound card? Frankieballsss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-01-2016 11:09 PM
MBox used as main sound card but sound is jerky Jonny5 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-03-2006 08:42 AM
Advice on Digi card with another sound card... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 08-11-2003 06:00 AM
How do i make my digidesign sound card my dedicated sound card? Frankieballsss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-04-2003 05:04 PM
pro tool free = no sound, how to make it see my sound card? spencedavey Digidesign Hardware & Software 1 01-03-2001 02:15 AM
