Mix Window - can meters be made bigger?
Hi there,
Is there any way to make the meters on the tracks in the mix window any bigger or longer? My control surface doesn't have any metering and I am relying on what's on screen. Is there any way to stretch the meters or is there a plug-in that would diplay the metering in a bigger format? Thanks, B. |
Re: Mix Window - can meters be made bigger?
The only fix I can think of is maybe getting a projector fed by your video card and then you can make it as big as you want.
I'm honestly not sure what kind of metering options you have outside of the stock meters. |
You can make the meters wider. I think it's command+click on the meter. There was a thread about it here recently.
How about trying the Bomb Factory Meter Bridge on a few tracks. They are free plug-ins. Of course they are RTAS Plug-Ins and would take up some processing power. You could just use it on the Master Fader or Buss Groups to conserve power.
Just for the record it's control+option+command+click on the meter.
Bigger VU Meters? | Final Lap Guy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 18 | 12-23-2009 12:36 PM |
Mix window meters = pre fader. | crsuribe | Pro Tools M-Powered (Win) | 3 | 04-29-2008 12:01 PM |
How do you make the movie window bigger? | Major Matt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-13-2006 04:09 AM |
Mix Window - can meters be made bigger? | bkee | Tips & Tricks | 3 | 04-27-2006 08:39 PM |
..how to make the quck time window bigger?! | spine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-16-2000 09:14 AM |
