  #51
Old 09-09-2010, 01:33 AM
MMAKINMITCH MMAKINMITCH is offline
Default Re: My Axiom Template for Pro Tools 8
When I move a fader it (arm record on a track)as I move a fader on my Axiom 61 instead of controlling a fader volume and thats got me puzzeled please help with your tamplate(THNKS)!!!
  #52
Old 09-13-2010, 04:43 AM
iyaron iyaron is offline
Originally Posted by gruddlebug View Post
Hello,
Here's my Axiom 49 (should be ok for 61 and 25 too?) template for Pro Tools 8 for anyone who's having trouble getting it working.
http://cid-7a6760c60f016df0.skydrive...se.aspx/Public
It replaces the default set of presets (although only preset 20 is actually changed).
Installation - Import the preset file into M-Audio's Enigma software (free download http://www.m-audio.com/index.php?do=products.enigma).
Select it and upload it to the Axiom (SYS should flash on the Axiom screen).When it stops flashing press Recall followed by 20 on the numeric
keypad to select Preset 20. In Pro Tools 8 go to Setup->Peripherals->Machine Control and enable MIDI Machine Control Remote (Slave) mode.
Then in MIDI Controllers Section, select MAudioKeyboard Port 1 for both Send and Receive, it should now work.
The template has the following functionality:-
Fader Buttons - These buttons let you select, record arm, mute, or solo tracks within Pro Tools By default, these
buttons select channels, however, pressing the button below the rightmost fader lets you step through three other functions:
record arm, mute, solo.
You can select multiple mixer channels by holding down the “Control” key on your computer keyboard while pressing the
fader buttons; holding the “Shift” key of your computer keyboard while pressing these buttons will select a range of mixer
channels. For example, holding the Ctrl key and pressing “1” and “5” will select the first and fifth mixer channels in Pro
Tools; holding the Shift key and pressing “1” and “5” will select channels one through five on the Pro Tools mixer.
Faders - These faders control their corresponding bank of eight faders in the Pro Tools mixer (initially 1 - 8). Note that all
Pro Tools track names that are currently under the control of Axiom are outlined in blue. If you click a track higher the 8
currently controlled then the faders will switch to controlling the next 8 (9 - 16 for example) this also works in reverse.
Master Fader - This fader automatically maps to the Master Fader track of your Pro Tools session; If you have not
created a Pro Tools Master Fader track, this fader will have no effect on your session.
Rotary Encoders -These are set to MIDI learn for control of plug-ins that support it (like Xpand2). Right click a parameter
in the plug-in an select Learn CC, twiddle a knob an it will take control of that parameter.
Note the track with the plug-in must be selected for MIDI learn to work.
Transport Controls -
Rewind -Tapping this button will skip to the beginning of the previous bar (or time/sample
delineation, if the Main Counter is set to show time or samples) Holding this button will
rewind the Pro Tools transport until the button is released.
Fast Forward - Tapping this button will skip to the beginning of the next bar (or time/sample delineation,
if the main counter is set to show time or samples). Holding this button will rewind the Pro Tools transport until the
button is released.
Stop - Stops recording or playback.
Play - Starts recording or playback.
Record - This button record-enables the Pro Tools transport.
Loop + Rewind - Return to Start
Holding down the Loop button while pressing the Rewind button rewinds to the
beginning of your Pro Tools session.
Loop + Fast Forward - Go to End
Holding down the Loop button while pressing the Fast Forward button advances to the
end of your Pro Tools session.
Loop + Stop - Undo
Holding down the Loop button while pressing the Stop button cancels the last action
that was made in Pro Tools (this is the same as selecting Edit > Undo within Pro Tools).
Loop + Play - Engage Loop Play
Holding down the Loop button while pressing the Play button engages looping between
the Loop Start and Loop End points as specified in the Pro Tools transport Press this
combination of buttons again to disengage looping.
Loop + Record - Engage Loop Record
Holding down the Loop button while pressing the Record button engages the “Loop
Record” function of Pro Tools Press this combination of buttons again to disengage
looping Please see the Pro Tools documentation to learn more about the loop recording
function.
Hope it's useful to someone
Cheers
evs
hi
do you have a suggestion of tutorials on a basic level? I do have Axiom Pro 49 . it seems very reliable but I need a step by step tutorial.
any suggestions?
I
Everyday Is A Good Day
http://www.bandmix.com/itzhak/ My Music
www.itzhakyaron.com
  #53
Old 11-04-2010, 12:27 AM
lopez_316us lopez_316us is offline
Originally Posted by iyaron View Post
hi
any suggestions?
I
Has anyone set this up with snow lepard?
  #54
Old 11-09-2010, 12:13 AM
Choral14 Choral14 is offline
I just found this and I must say: Than you very much!
  #55
Old 11-15-2010, 09:23 AM
Hi
Need a clarificatio nabout Axim 49 and Axiom Pro 49 I think the pro has a new software are you suggesting the template for the Axiom Pro 49?
Also wehre can I find tutorials how to use Axiom Pro 49?
thank you.
www.itzhakyaron.com
  #56
Old 12-09-2010, 09:09 AM
Hey everyone,
So I downloaded the temples and It work great, but only the trasport controls. I can control the virtual instruments!!! Any help how can I do that?
Thanks,
  #57
Old 12-09-2010, 09:11 AM
Originally Posted by lopez_316us View Post
Hey everyone,
Thanks,
I forgot to mention that my system is a Intel Imac i3 newest system with snow leopard. And I'm trying to setup the first gen Axion 49.
Thanks,
  #58
Old 12-12-2010, 10:43 PM
Hello,
button is released.
Loop + Stop - Undo
function.
Cheers
evs
www.itzhakyaron.com
  #59
Old 12-12-2010, 10:44 PM
is this for Axiom pro 49 as well?
www.itzhakyaron.com
  #60
Old 12-13-2010, 10:15 AM
Jay_uk Jay_uk is offline
Who has not read the thread then?
Okay as its close to Christmas
Start at post 50
Novation Launchpad Pro Tools Edit template frabo Tips & Tricks 8 08-31-2016 01:11 PM
Eleven Rack Pro Tools 11 template is blank / broken sbaures Eleven Rack 10 01-29-2014 11:10 AM
Tested out a Template, now Pro Tools is ruined! ThirteenInvitations macOS 5 09-17-2013 07:24 AM
A little help please = Axiom 49 & Pro Tools 8 LE Bongo5HH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-15-2009 03:03 PM
Have Pro Tools Automatically Open Template elankf1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-13-2006 02:50 PM
