System Hangs on "Creating DAE Objects" In Vista 32 w/ Digi003
OK. I am starting to get a little frustrated. I have a new Dell Core i7 comptuer (See Specs Below in Signature Panel) that shipped with Windows Vista Ultimate 64-Bit. I have since learned that PT does not like any Firewire Audio Interfaces in any 64-Bit OS (Mbox via usb works fine). I have since reloaded with Windows Vista Ultimate 32-Bit Edition. I had a fresh install. Loaded my display & chipset drivers, then loaded ProTools. After a reboot, I start PTLE 7.4 with my Digi003 hooked up and the system hangs on "Creating DAE Objects" (The same place it hung on Vista-64. If I close PT, disconnect my digi003, connect my mbox, then start PT again, it works fine. Does anyone have any ideas?
______________________________________ Jason Computer: Dell Intel Core i7 920 @ 2.63GHz w/ 6GB Tri-Channel DDR-3 RAM Boot 1 (Primary): Windows Vista Ultimate 32-Bit / ProTools LE 7.4 cs8 / Digi003 Rack Boot 2: Windows Vista Ultimate 64-Bit / ProTools LE 7.4 cs8 / Mbox 2 (Waiting impatiently for 64-Bit Firewire Support) Boot 3: Windows 7 Ultimate 64-Bit / ProTools LE 8.0 cs2 / Mbox 2 (Waiting impatiently for 64-Bit Firewire Support) |
Re: System Hangs on "Creating DAE Objects" In Vista 32 w/ Digi003
OK, I finally got it working. All I had to do was switch the firewire port that Vista was plugged into (From the aprooved SIIG card to the one that is on my MOBO) and right click on PT LE 7.4 and select run as administrator.
Protools 8 Freezes at "Creating Dae Objects" upon Launch? | MythMuzik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 04-22-2011 07:53 PM |
PT LE 8.0.3 Won't Start up! (hangs on "creating DAE objects) | 003worksforme | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-07-2010 09:39 AM |
Pro Tools LE (7 & 8) "creating DAE objects" freeze | glitchbent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 04-22-2010 02:22 PM |
M-Powered 7.4cs2 Freezes on "Creating DAE Objects" | Haon99 | Pro Tools M-Powered (Win) | 6 | 03-29-2009 09:26 PM |
Launch Freezes @ "creating DAE objects" | affliCted | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-02-2009 06:32 AM |
