Old 12-05-1999, 08:34 PM
delphypop delphypop is offline
Default accidental erasure and Un erasing SD2 files
Just did the unthinkable and erased a couple of files by accident due to a little quirk in PT.
When I last saved I had the last file I had bounced to disc and finished with hi-lighted.
I closed the session downand then came back to it a couple of hours later.
when thesession open I saw the file hi-lighted and thought cool, delete that and move on to the next track I was mastering.
Command shift b, delete tracks, option click yes, and..... just accidently deleted everthing.
When PT opens it automatically selects everything in the take directory, why? ,I don't know.
You can have a file hi-lighted in the edit window but not just it's file or region hi-lighted in the take directory, there by leading to the possiblity of accidental erasure.
Is there a preference switch to make the take directory and edit window files lock together?
secondly I tried to unerase the files using nortons disc doctor and it couldn't find them. I've noticed this before.
What is it about SD2 files that Nortons nerase doesn't see. Howcome I can't unerase these files? I tried to get nortons to recognise the file type and search for that only but it bought up all these 68 k files that didn't have any info in them. Is the sound data stored in some sort of hidden resourc fork?
Can anyone shed some light on better setup proceedures to avoid accidental erasure, and give me some advice on how to best recall accidently erased files
Thanks in advance
Cheers
Rob
Old 12-06-1999, 07:19 AM
MrKnewitAll MrKnewitAll is offline
Default Re: accidental erasure and Un erasing SD2 files
Patient: Hey, Doc, everytime I hit delete, something gets deleted. What should I do?
Doctor: Don't hit delete.
The most elegant solution to your problem is to be aware of this quirk and be smarter than the computer: don't do that again.
I have never had success in unerasing files either.
Best of luck.
Anyone who isn't confused, really doesn't understand the situation.
Old 12-07-1999, 12:10 AM
Techsupt2 Techsupt2 is offline
delphypop
advice on how to recall accidently erased files
Try Disk Warrior from Alsoft:
www.alsoft.com
Brad
[This message has been edited by Techsupt2 (edited 12-07-99).]
Old 12-07-1999, 06:42 PM
reeder0000 reeder0000 is offline
I have also accidentally deleted audio files recently and could not retrieve them with Norton's. Did you find a way to recover them that worked?
Old 12-07-1999, 08:13 PM
thanks mrknewitallfor stating theobvious
I know how not to delete files but with the ever increasing time pressure to do things faster mistakes happen and it would be cool if things worked so that you don't have setups defaulting to possibly dangerous situations.
my suggestion for a way around this is
1) don't have PT default to select all on start up. Why does it do this anyway?
2) have it so that PT edit window and the take dirctory selection are locked together, there by removing the possiblity of thinking you have one thing selected for deletion and actually having a whole bunch of other items.
Thanks for the advice on disc worrior brad. Do you have any idea on why the files don't show up with nortons?
Cheers
Rob
Old 12-07-1999, 08:18 PM
diskq warrior is $69.95
It would becool if it was possible to do what I want with the software I have.
I'd like to know if and how it's possible to retrive files with nortons
Old 12-09-1999, 09:14 PM
tech support - any insight into sd2 files and how to make them recoverable?
Old 12-10-1999, 04:00 PM
Przemek Przemek is offline
GREAT GREAT tip from sb froom digi - I've got it from DUC, and the same day I had to check it. If you're in trouble, try it: If you ereaed sth, do nothing! Create a session, put track (or tracks, remember 2GB per track space limit) in record mode, start recording and IMMIDIATELY switch off your rig! You'll get one (or more) files , which occupy whole drive. Import them to the session and listen to them (I know it takes some time, in my case 2 hours) and all your audio will be there - fragmented, of course. But it WORKS! (I know it is not elegant solution).
Przemek.
http://imaginatlh.com/91709
Old 12-10-1999, 05:30 PM
snake snake is offline
Wow interesting idea. I've heard of that happening but never used it as a recovery tool. Very cool.
BTW - There is a preference to link your bin and timeline selections. Look under prefs/editing/track selection follows region list and regions list follows track selection.
Erasing Back-Up Session Files RichrdC Pro Tools M-Powered (Win) 1 08-31-2009 11:53 AM
Accidental deletion PSIII MIDI 4 06-12-2008 04:35 PM
Unused Audio Files NOT ERASING!!! kiwishock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-24-2007 06:51 AM
Accidental Deletion 2A Batterie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-12-2006 07:07 AM
accidental fades = !@#$! monkey Pro Tools TDM Systems (Mac) 5 01-12-2004 11:24 PM
