#21
Re: Hdx do not work!!! **!%
Do you mean Digitest does see the card? If so, does it pass or fail?
#22
no no he does not see it, he only sees the system preferences
Capsuletta www.legrenierstudio.it Mac Book pro (I7 - 3,1GHz - 16gb Ram) OS Sierra Pro tools Ultimate 2018.10 HDX |
#23
Well amazingly the card being identified does not mean much...
Is that in a different system or the Thunderbolt expansion chassis, and again is the power cable connected to the card? And did you check with a multimeter? If you can Digitest the card in a different system... or give up and return it. But if the card came from a friend and is known to work then suspect your expansion chassis setup, which is why I keep asking about the power. If you put it back in the exact friend’s computer it was working in before does it work again? |
#24
#25
What exactly happens when you run Digitest on a fresh reboot?
(Do not attempt to launch Pro Tools before running the Digitest application.)
#26
nothing
#27
Okay. I see. I have no good ideas beyond suspecting the card.
#28
Are there any possibilities that the card isn't good? How can I find out?
#29
What computers have you tested in? We cannot tell if you only have tested with the expansion chassis. Again in that chassis check the power supply to the card....
#30
Hello friends
last night I spent the evening in remote with avid usa. and unfortunately, the card is damaged, the mac fails to display it, we have installed various drivers new and old but nothing, the only solution is to send it in assistance, I hope only in a replacement, thanks for your answers
My Pro Tools does not work! I can't get it to work with iLok | jarred89 | Licensing & Accounts | 19 | 11-08-2016 12:27 PM |
Next Victim - Artist surfaces do not work with PT11 but work fine with PT10 | jimmyjayp | Artist Series | 10 | 12-29-2014 03:38 PM |
Mackie Universal control Pro only work with protools11 dose not work 10.3.9 why??? | sayed mohammed | Windows | 6 | 11-11-2014 08:22 PM |
Audio Suite plugins that work in 10, do they work in 11? | David Sandwisch | Windows | 1 | 08-10-2013 08:14 PM |
How does Direct Connect work?? (Does it work well??) | tommydee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-18-2001 08:13 AM |
