PT 10HD with MXF Video wants Video Engine?
Hi there
I own two systems, both OS X 10.6.8 with PT HD 10.3.9. One is a Hackintosh with Accel hardware, the other a Mac mini. On the one Mac with Accel hardware, I'm able to import vide tracks from a MXF file. On the Mac min, I get a "Video Engine not installed" message, when I try to import the same file. Maybe this is a wrong error message and there's just missing the proper video codec? Or does it work only when Accel cards are installed? That would be very strange... Cheers T |
Re: PT 10HD with MXF Video wants Video Engine?
Try install pt 10, stick : videoengine
- iBook G3/800 14-Inch (32 VRAM - Tr) - eMac G4/1.42 (2005) - iMac G4/1.0 15-Inch "FP" (USB 2.0) - iMac "Core Duo" 1.83 17-Inch - PowerMac G4 867MHz + Dual 1.25 - PowerMac G5 Dual 2.0 + 2.3 - Mac Pro 1.1, 2.1 - MC374 - Mac Pro 5.1 - Digidesign Protool Mix Plus 5.1.3cs11, 6.4.1cs4, LE 7, LE 8 - Avid Pro Tools HD 9.0.6 + 10.3.10 Native + 11.3.2 + 12.5.2 , 003 , Avid Mbox 3 Pro , ProControl , Control24 ... |
Are you using either a Mojo or a Mojo SDI with the HD system? You can only playback Avid MXF media with v10 if you have either a Mojo or Mojo SDI. Both types of Mojo peripherals require the video engine be installed.
Video Engine in PT 11.1 | yop22 | Post - Surround - Video | 294 | 07-30-2014 08:03 AM |
Boot Screen "Not Recognized Video Hardware Connected", "video engine failed to init | bcrichguitar | macOS | 3 | 04-01-2012 09:10 AM |
Video engine | Bender | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-22-2010 06:30 PM |
How do I get rid of the Video Engine? | notr2d2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-31-2009 09:51 AM |
Where's the Video Engine? | admix | Post - Surround - Video | 4 | 05-02-2008 04:51 PM |
