Old 05-29-2023, 11:00 AM
evanmd evanmd is offline
Default No return signal for hardware inserts
I'm having an issue where I can't get the return signal to come back into pro tools when I engage a hardware insert. The hardware is getting the output signal though. This all started when I added a switch craft patch bay; there wasn't a problem before.
I have tested the paths by selecting the hardware piece as an output on a track, and recording it back into PT on a new track using the hardware as the input. That works just fine which tells me everything is connected right. I have a Lynx 16(n) interface and PT version 2018.1.0.
I have attached pictures of my I/O.
Old 05-29-2023, 11:46 AM
Craig F Craig F is offline
Default Re: No return signal for hardware inserts
what style of patchbay? have you tested it's continuity?
Thank you,
Craig
Old 05-29-2023, 11:49 AM
K Roche's Avatar
K Roche K Roche is offline
Humm I don't use a patch bay and I do use an Avid Carbon as my interface so consider that.
And If I am understanding you correctly
To use hardware as an "Insert" in PT , in the PT I/O The input and output have to be the same channel number.
Your I/O is showing radically different channels between the "Input" and "Output" tabs
For example you are showing your-- Tube Tech "Input" as channel 6 and it's "Output" as channel 3
On my system (again no patch bay but direct into and out of the Carbon interface )
So for example my two channel Bus Comp labeled (3U) = Input and Output are channels 5&6.
And My stereo HW Reverb - (M7) Inputs and Outputs on 7&8
And My "Insert tab" shows the same, 3U as 5&6 and M7 as 7&8
Input tab
Output tab
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 05-29-2023, 11:51 AM
nsureit nsureit is offline
Are the patch bay circuits "normalled" correctly?
Its a Switchcraft Studio Patch 6425 64-point TT - DB25 Patchbay. I'm not sure what you mean by testing its continuity. I have made sure that the signal is running through the patchbay by using the hardware as the output on an audio track, and recording back into PT on another track with the hardware as the input.
Old 05-29-2023, 11:53 AM
The patchbay is full normalled. I really don't think its the patchbay; I suspect I have something messed up inside PT.
Old 05-29-2023, 11:54 AM
K Roche's Avatar
Yes see my post You have different input and output channels
System :
Enjoy the Journey
.... Kev...
Old 05-29-2023, 12:03 PM
I knew I was an idiot. Cheers.
Pro Tools 12 and RME TotalMix - using hardware inserts send/return DAT11 macOS 5 04-27-2017 03:41 AM
Bypass inserts then return to unbypassed state? bassmagnetic Avid S1, S3, Dock and Control App 0 01-29-2016 07:35 AM
Are mixer inserts used sequentially in a signal chain? illution1 Pro Tools 10 1 01-28-2014 01:58 PM
Hardware insert 1&2 cutting off other hardware inserts on aux tracks Led Windows 4 12-09-2013 09:19 AM
Instrument Track Inserts B+ no midi signal rmoat Windows 3 01-15-2011 04:49 PM
