Old 07-17-2021, 07:48 PM
dg27's Avatar
dg27 dg27 is offline
Default PT 2021.6: Windows 10 versions: Is Build 21H1 required?
I was just reading the minimum system requirements for PT (Native) 2021.6.
At the very top it says this:
System Requirements and Compatibility with Pro Tools 2021.6 Software
Windows 10 64-bit build 21H1
I'm running Version 1909 (Build 18363.1556).
Is Build 21H1 really essential? Has anyone run PT 2021.6 on Windows 10 Build 1909?
Based on the Avid Compatibility Chart, it looks like the newest version I can install is 2020.12.
Be Quiet Pure Base 600 case * Core i5-12600K * Gigabyte Z690 UD AX * 32 GB G.Skill Ripjaws DDR4 * 2X HP DreamColor Z24x G2 displays * NVIDIA GeForce GTX 960 * Samsung 980 boot drive * Samsung 870 EVO PT projects drive * Samsung 860 EVO PT archive drive * Novation Impulse 49 MIDI * PreSonus Studio 26c interface * PreSonus Bluetube V2 preamp * PreSonus HP4 headphone amp * JBL LR 305 monitors * Sennheiser HD 650 headphones *
Windows 10 Pro 64 21H2, Pro Tools 2022.7.0
Old 07-18-2021, 08:34 AM
ibbod0 ibbod0 is offline
Default Re: PT 2021.6: Windows 10 versions: Is Build 21H1 required?
It's certainly not "essential" and I don't think anything important that would affect Pro Tools has changed between your Windows version and the current one. I'm using 20H2 myself... at my own risk
Old 07-18-2021, 08:40 AM
JFreak's Avatar
JFreak JFreak is offline
It is supported only on 21H1, may work on earlier builds but Avid will not help you in case you have problem with unsupported OS/PT combination
Janne
Old 07-18-2021, 02:33 PM
dg27's Avatar
Thanks.
I updated Windows 10 to Build 2004 and will install PT version 2020.12, which is listed on their compatibility chart.
Crossgrade to 2021 and access to older versions? zeeman Licensing & Accounts 15 07-23-2021 04:47 AM
Any known issues with PT 2021.6 in Windows 10 justjohnmusic99 Pro Tools 8 07-16-2021 05:47 AM
2021.6 and the new windows 11 kobi_dog Pro Tools 13 06-28-2021 10:06 AM
Windows® 10 Version 21H1 taylor4814 Pro Tools 9 05-20-2021 04:25 PM
Why is Administrator access required in OS X versions?!?! tcassel Pro Tools TDM Systems (Mac) 10 07-11-2003 02:33 PM
