Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 04-23-2020, 05:33 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Default Track Presets Do Not Open Closed Folder Tracks
Hey guys,
While creating track presets to use in building work templates, I felt it would be nice to save some screen real estate, so I closed the folder tracks before saving them as track presets. When I imported the presets, the folder tracks were empty/wouldn't open. This is a serious bug! I was fortunate to have also saved my work as a session, and that enabled me to re-save the track presets with open folder tracks, which worked.
Has anyone else seen this?
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 04-24-2020, 01:40 PM
lesbrunn's Avatar
Default Re: Track Presets Do Not Open Closed Folder Tracks
Hey guys,
Nobody seemed to take this issue seriously, maybe because I didn't explain it well. If it's as I think it is, then Avid should address this asap.
All data is lost when you save a closed folder track as a track preset.
Please try this:
1. Create a few tracks (these could be audio, instrument, aux, whatever)
2. Move them into a folder track (any type).
3. Close the folder track and save it as a track preset.
4. Recall the track preset that you just saved.
In my case, the folder track cannot be opened. The size of the folder indicates that the contents are missing. Please try this and let's see if anyone has this issue. Thanks
Old 04-25-2020, 01:50 AM
ibbod0 ibbod0 is offline
Same here, seems like the folder is empty.
Old 04-25-2020, 09:45 AM
lesbrunn's Avatar
At last! I've found someone else who has seen this huge bug. Honestly, the initial response was disappointing. Maybe not many people work this way. I reported it to Avid, but they never seem to reply. You can also report it. Avid never seems to take things like this seriously,
Maybe they will if enough people complain...
I'm in the process of recreating my templates using folder tracks. Apart from large mix templates, I have lots of VI's and other stuff that I import into sessions. The idea was to give these imports a small footprint (because the sessions already have lots of tracks) so I can open them as and when needed, but the purpose is defeated.
Old 04-25-2020, 09:47 AM
lesbrunn's Avatar
BTW I also posted this in the folder track requests thread when nobody replied here. May be that's the best place for this.
Old 04-27-2020, 02:56 AM
bartosz idzi bartosz idzi is offline
Did you tick "Include All Member Tracks" when saving the folder? Easy to miss...
All working fine here...
Mac Pro 2 x X5690 3.46Ghz - 64 Gb RAM - SSD 256 Gb - SSD 1TB - OS 10.14.6 - Metric Halo 2882 + Lucid 88192 - Pro Tools Ultimate 2020.11
Old 04-28-2020, 02:11 PM
lesbrunn's Avatar
Thanks bartosz idzi, got it. All good now...
Are Pro Tools new Folder tracks the same as Logic Track Stacks? Kerochan Pro Tools 2020 3 04-04-2020 07:40 AM
Track Presets Folder Location ShiftStudios Pro Tools 12 11 02-12-2016 10:55 AM
Accidently closed my Tracks window, how re open? Danny Winn Pro Tools 10 5 08-05-2012 02:12 AM
Can't save with 'tracks' window closed? RaySoul 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-23-2009 06:27 PM
Closed or Open Backed Headphones? GTBannah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-16-2008 11:07 AM
