Old 03-04-2019, 01:46 PM
helenvee helenvee is offline
Default PT 2018 Center on Selection Shortcut in MIDI Editor Window
I frequently use the right/left arrow keys to center on selection, i.e., if my cursor is outside of the area currently shown in the frame, the arrow keys will move your view frame so that the cursor is in the center of it, so you can quickly jump to wherever your cursor is without having to zoom out and then in again. However, with the new PT 2018 MIDI editing shortcuts, now when you're in the MIDI editor window, the right and left arrows select a MIDI note and move you to the next or previous MIDI note. Has the Center On Selection shortcut been moved somewhere else when you're in the MIDI editor window, or is this shortcut no longer possible in this window?
Old 03-04-2019, 06:12 PM
ibbod0 ibbod0 is offline
Default Re: PT 2018 Center on Selection Shortcut in MIDI Editor Window
I found there's a little blue arrow you can click in the main ruler in the midi editor window. no longer any keyboard shortcut as far as I know.
Quick shortcut to center screen around selection? SigFriedChicken Pro Tools 2018 8 11-20-2020 10:26 AM
2018.7 Midi editor defaults tjcriffler Pro Tools 2018 5 08-17-2018 09:42 PM
Make MIDI editor track selection independent of edit window? tooold Pro Tools 11 3 01-30-2015 10:34 AM
Any shortcut to audition selection in edit window? Tom M macOS 3 07-19-2013 10:45 PM
[B]PT 8 Docked Midi Editor Shortcut[/B] Heck 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-19-2008 07:54 PM
