Record Enable at all times possible ?
Is there a way to have a track always on record enable ?
What’s the reason?
You could more than likely just have input monitoring enabled on the tracks. From memory, input monitoring stays enabled even on session close/load. Sent from my iPhone using Tapatalk |
Re: Record Enable at all times possible ?
I meant record enable on a midi and / or instrument track.
I have Scaler as insert on an Instrument channel and I want midi played from my main controller flowing to it no matter which other instrument I'm using at the time. |
Sure, go to Setup, Preferences, MIDI, Default Thru Instrument and select the plugin you want to trigger.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
I was looking for the same thing, something like a midi aux track for routing of internal midi data generated by plugins. Seems like default thru instrument is only good for external MIDI coming in.
Thanks, exactly what I was looking for :)
How to Record Arm Record Enable using Axiom Pro Hyper Control | Cosme | MIDI | 1 | 04-16-2013 04:56 AM |
RECORD Button Blinks Five Times Before Starting | fivefilms | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-16-2009 12:38 AM |
PT8 - HUI record enable leads to record-safe | JMDNYC | Pro Tools TDM Systems (Mac) | 0 | 12-30-2008 06:33 AM |
Static Sound After Record Undo and Other Times | planethood | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-13-2006 07:59 PM |
Urgent: Record Enable greyed out--can't record! | FlyingDisc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-25-2001 09:55 AM |
