Old 09-28-2017, 07:16 AM
hanstondo hanstondo is offline
Default commit midi on PT12.7.1. with VEPRO slave
I'm having problems to commit midi tracks to audio on PT 12.7.1
Midi is on separate midi tracks, routed to VEPRO instances on a instrument track (not aux tracks, which have other problems)
On committing, some work fine, but others give this error message.
-could not complete command because assertion in Volumes/Development/200028/Protools/NewFileLibs?Mdie/CMidiInstrument.... -see attachment -
Sometimes disabling the VEPRO connecting and reconnecting helps, other times it only works again after committing some other tracks. Weird. On some occasions all midi tracks routed to that particular VEPRO instance loose their routing.
Anyone have same issues ? PT12.8.1 also has problems with commit, so that's no solution
PT 12.7.1 on Mac Sierra 10.12.3 6core 3,46Gz 48Gb ram NVIDIA GTX970 graphics
2 x WIN 10 slaves - 8core i7 6800 - 32G Ram running VEPRO6 latest build
Old 09-28-2017, 07:36 AM
Default Re: commit midi on PT12.7.1. with VEPRO slave
and forgot to mention, every 5 or 6 commits, I also get the spinning wheel, protools unresponsive , but after about a minute, or two, the track appears and protools is back.
Tried all solutions on this forum for that problem (clean install of 12.7.1, disk permissions, etc...)
Not sure if the two problems are connected, but on committing, I can reproduce it time after time. Sometimes it happens on opening a session (the sessions are quite big, containing video - in avid format - and lots of instrument/midi tracks)
VEPro Plugin not found in ProTools 12 Session after upgrade from VEP 5 to VEP 6 PT12 z_jerry AAX Plug-ins 4 12-29-2016 06:27 AM
VEPro 5 on a slave Mac Pro - Dropouts Imagine Pro Tools TDM Systems (Mac) 0 12-06-2011 12:24 AM
Good computer for VEPro as slave? Ray Lyon Virtual Instruments 3 03-14-2011 06:39 AM
VEPro on Slave Mac Imagine Pro Tools TDM Systems (Mac) 10 10-14-2010 11:25 AM
