Old 12-12-2011, 05:19 PM
WildHoney WildHoney is offline
Default Will my blue Sync HD work with the upcoming HDX systems?
and is there any difference b/w the older digi blue sync hd's and the newer avid sync hd's practically speaking?
Old 12-12-2011, 06:20 PM
KMcK KMcK is offline
Default Re: Will my blue Sync HD work with the upcoming HDX systems?
Pro Tools 10 will be the final supported feature release for legacy Digidesign interfaces and controllers, including:
192 I/O, 192 Digital I/O, 96 I/O, 96i I/O, SYNC (original "blue"), SYNC HD (original "blue"), MIDI I/O, 003 family, Mbox 2 family, Control|24, Command|8, Pro Control
Old 12-12-2011, 06:33 PM
Craig F Craig F is offline
what is odd is when the Sync HD came out we were told is that it was only a skin job and currently both units use the same Firmware package from what I can tell
there is no separate package for blue or gray (OMG Avid's having an Civil War identity crisis)
Thank you,
Craig
Old 12-12-2011, 07:25 PM
Originally Posted by Craig F View Post
what is odd is hen the Sync HD came out we were told is that it was only a skin job and currently both units use the same Firmware package from what I can tell
I recall the same story. And quickly looking at the new unit, I'm not sure what it does that the blue Sync HD doesn't.
Old 12-12-2011, 08:51 PM
the dude's Avatar
the dude the dude is offline
NOT true at all
The Sync HD is exactly that… (HD) it has the ability to use and lock to all the current HD frame rates for HD/SDI and is update-able if and when the 2K and 4K formats become more abundant in use
The Sync IO uses firmware 1.2x and the Sync HD uses Firmware 2.2x
this also reflects the improved frame rate support as mentioned
The sync IO will work fine with the HDX cards it just won't work with HD/SDI, and SDI frame-rates
Now wheather or not future software updates will allow it or deny its function-ability is completely up to Avid at their digression
( its a software function ) HDX hardware and Current hardware are at the HW level functions shouldn't be a frame rate dependent issue
FYI the Sync HD video input will not sync to serial video ,( NTSC, PAL only )
which seems unusual because it won't allow the video burn window using HD/SDI or SDI signals
http://www.studio-techservices.com
าำ
[email protected]m
Mitch Berger Tech Services
We service ALL Avid products no Problem
HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything
ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around
inquiry using link above
Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear
Old 12-12-2011, 09:42 PM
Dolly Dolly is offline
The dude,
The discussion here is about the (lack of) differencies between blue Sync HD and gray Sync HD, not about the differencies between Sync IO and Sync HD.
Old 12-13-2011, 05:39 AM
But is there any difference b/w the Digi Sync HD (blue) and the Avid Sync HD (gray) other than its support-ability beyond PT10?
Old 12-13-2011, 11:33 AM
Originally Posted by the dude View Post
NOT true at all
you miss read me:
the blue and the gray Sync HD use the same firmware
the Sync IO has been dead to me for years
Thank you,
Craig
Old 06-07-2014, 08:51 AM
notable's Avatar
notable notable is offline
Actually my Sync I/O has been going strong with My HDX mac rig for months in PT 10. BUT when I go to 11 it stops working. :{
PS I use the serial mac cables from 10 year ago. The printer cables…
Notable.com
AfricanUnderground.com
DemocracyinDakar.com
NomadicWax.com
Old 06-07-2014, 09:27 AM
JFreak's Avatar
JFreak JFreak is online now
Yes, don't get confused here -- there are three sync boxes:
- Digidesign Sync I/O (blue)
- Digidesign Sync HD (blue)
- Avid Sync HD (grey)
AFAIK, both Sync HD's are the same, but very much different than the original Sync I/O.
Janne
Sync HD BLUE + PT 11 HD rcutz Pro Tools 11 1 12-04-2013 02:13 PM
Sync-blue and midi-blue with protools 11? John Becool Pro Tools 11 4 09-11-2013 10:28 AM
How To Sync Two PT Systems. t_pov macOS 3 10-08-2012 02:14 PM
SYNC two MIX Systems Indigo Studio Pro Tools TDM Systems (Mac) 1 04-24-2008 03:40 PM
Sync Two Mix systems? Dog BBQ Pro Tools TDM Systems (Mac) 3 12-15-2003 08:20 AM
