#4631
Re: i7 Builds - Specs and Results
Hey Guys,
I originally posted on here when everyone was just started building their i7 boxes. Based on everyone's help and advice I got a sweet i7 build up and running without too much issue, and it has served me well for over two years. That build was XP based with PTLE 7.3 I finally decided to upgrade so I could take full advantage of all my RAM (and upgrade to 16GB), a 64bit OS, and newer software, so I installed Win7 and PTLE8 ( I know 9 is better, but I gotz no cheddar) My system that was running pretty flawlessly on XP after the initial debugging, but now when I try to run PTLE8, I bluescreen (errors vary each time) and the whole system crashes. When I reboot I have a dialogue that states DAE error 1115. I researched the 1115 error here and on the net and saw that it can be due to USB controllers (not likely as I am using FW) or FW issues. I have done some debugging on my end (BIOS tweaks, checked both firewire ports, and firewire cord, etc) but still getting the same results. Most people that I read had DAE 1115 errors did not also have bsod issues. I suspect the mobo, but before I start ripping my system down or revert back to the old install, I thought I would check here. Since I figure many of you on here have the same hardware as I do (since I picked my specs based on advice on this forum) I was hoping that some of you have had the same issue and were able to resolve it. Any help would be greatly appreciated. I left my XP install standing on a different partition, but I'd really like to upgrade if possible. My specs: DIGI002 PTLE 8.0 Mobo: GIGABYTE EX58-UD3R CPU: i7 920 DO Stepping (Batch B) 6GB OCZ Gold DDR3 1600 GIGABYTE EX58-UD3R mobo i7 920 DO Stepping (Batch B) RAM: 6GB OCZ Gold DDR3 1600 Storage: System HDD, WD Velociraptor 300GB partitioned into 2 drives, one 60GB for OS and Protools app, remainder for data. 2nd HDD WD Caviar Black 1TB partitioned into 4 +/-250GB drives CDROM: 2 Samsung DVD-RW's VIDEO: Sparkle GeForce 9500GT CASE: Antec 900 PSU: Corsair HX620 620W PSU |
#4632
I have managed to find myself a DP67BG so I would think this would be a safer option than a Z68 chipset. As for the RAID, I have done a little bit more research and found that most users that are having issues are using software RAID rather than hardware. I will be using hardware RAID 1, just for data redundancy sake on my audio drives. If I have issues with RAID, I'll just use the second hard disk as a plain old back up drive. I'll take my chances with SSD boot up drive, but from reading through the forums a little more, there are plenty of success stories. Anybody have good/bad experiences with a DP67BG?? I see there is one in the header at the start of this sticky. Cheers! |
#4633
RAID? Even though Hardware RAID1 might work I haven't tested it for audio recording. Just so you know, the rule is no RAID.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9 |
#4634
Unless you're running Pro Tools 10 that supports RAID but does not guarantee performance.
Aaron Mulqueen - 001 HD Native |
#4635
Thanks guys!! These are the components I went with:
I installed PT8 last night to test, and it ran like a wet dream. There was a little issue when I got the 'Audio Record Volume' error, but that was a quick fix by changing the drives to 'R' from 'T'. I was running Melodyne and strike and she purr'ed along. I'll install PT9 as soon as it's delivered. Just so I got it right, I had my buddy that works at a nuclear plant as a system engineer help me. He's also a tube amp wizard. I think he had multiple geek orgasms the whole time we assembled it. |
#4636
#4637
#4638
Thanks, I actually didn't want to be the trailblazer (guinea pig), but oh well, hehe.
The system is stock and I'll try and do a dverb tonight. |
#4639
congrats!!! post back with your dverb results and i'll post build and results on page 1
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#4640
Ok Tests Completed.
Just a background. To save money on the build I used a combo of new and old. Not the best, but will replace when the wife's shock is abated. Operating system - Win7 64-bit, corporate version Protools - PT8.0.5 on a 002R. Probably move to PT10 in a week or so. The new componenets:
I did two set of test. The first is without any of the Win7 optimization (listed one first page), and the next was with the optimization except: 'disable system start-up items', 'HD optimization' (newly formatted drives), 'Install latest device drivers (PT9 only)', 'disable USB power mgnt', 'not hearing input/output' (not an issue), 'disable network adapters', or any of the others listed after. Dverb 1024 (without optimizations) = 484 with CPU(RTAS) at 89% Dverb 1024 (with selected optimizations) = 621 with CPU(RTAS) at 89% Dverb 64 (with selected optimizations) = 473 with CPU(RTAS) at 86% I was floored how much the dverb jumped after the optimizations :P I guess putting the PT files on my 'oldest' HDs isn't the best. That'll be one the first changes. I used to have to run my old system in 'disable system start-up items' all the time, so I'll use that for big mixes. I'm still open to impoving now that the MB and cpu are ok. Cheers |
Best Core 2 Series Desktops-Results and Specs | sunburst79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2416 | 02-19-2013 07:49 PM |
new to pc builds | chazc080488 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-18-2011 07:10 PM |
any p45 builds | fofif5792 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-09-2008 12:47 PM |
OSX "builds" | Richard Barrie | Pro Tools TDM Systems (Mac) | 2 | 10-18-2004 08:37 AM |
