Internal SATA versus External Firewire
Need new drives. I would either do a internal SATA 7200rpm like this one:
http://www.newegg.com/Product/Produc...82E16822148140 Or I could go with an external drive in a chassis with a firewire interface like the one digi recommends like this: http://www.newegg.com/Product/Produc...82E16822154069 Aside from the obvious portability of the Firewired drive, would there be any advantages to either? If you could even point me too a couple threads on the subject that would be most helpful. I did some searching, but couldn't find a thread comparing the two. Thanks
You gotta get it in the mic! |
Re: Internal SATA versus External Firewire
I put a Western Digital 150 gig 10K internal SATA in my G5 for recording. Haven't done any 96K sessions, but at 48K I can and have easily done 100 tracks. I use Firewire to backup. It is a pretty solid and quiet drive.
Rob |
mmmmmm that sounds tasty. Is that the Raptor? I though about that route, but as I only handle around 32-48 tracks per session I'm not sure I need to worry that much about speed. I could be wrong tough. Sounds like the SATA buss will not be the bottleneck so I shouldn't worry about it then?
I'd go with the Seagate and never look back! I've used Seagate drives for the last 16+ years and NEVER had issues!! Our current PTHD systems (4 of them) are using external Ultra320 (SCSI) but we also have an internal 250GB SATA in our G5s that works great. We use it as temp storage, but PT sees it as a real, working drive.
5-year warranty can't hurt....
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
How much better is the performance of a 10K internal SATA drive than a 7.2K RPM internal SATA as far as Pro Tools is concerned? Does it really improve track counts, screen redraws, etc.?
It looks like the WD Raptor X might be the only real option, and they only make a 150 GB size. The seek times look to about nearly twice as fast as the 7200 models, but it is hard to compare transfer rates, since they use bytes for one model and bits for the other, but from my calculations the transfer rate on the 10K drive are slower. I have had some strange issues, such as plug ins and auxes randomly stopping passing audio, that some have suggested may be from running too many tracks from one drive. Maybe this drive would help.
www.clifnorrell.com |
The internal SATA drives are faster than FireWire and will give you better performance. Ideally, you record to the internal SATA, and then back up to FireWire.
I'm running a WD Raptor 150 gigs.... It's totally great! On "normal" <80 tracks sessions I can run on DAE playback buffer "0" for much of the time, which is way cool as the system is very fast and responsive... And I've done a couple of 200+ tracks session with maxed voices which run ok with the playback buffer on only "2". I don't think a 7200 SATA or a FW drive could run such a session at all!
I'm running a Quad 2,5 G5 with HD Accel3... 4,5 gigs of ram. And yes, backups to FW800.
Windows 11 23H2, Intel i9-14900KS, MSI PRO Z690-A D4, 64 GB DDR4 4000MHz/CL18, Corsair HX1000, 1TB M.2 PCIe 4.0, 5TB M.2 PCIe 3.0, 2TB QVO, 2x6TB WD Black, Noctua NH-D15, Fractal Design Define R6 + RTX4070 - PT Ultimate 2024.3 Used to be/ Spare/ DAPS: Mac Pro 4,1 upgraded to 5,1 3,46Ghz 12 Core, 96GB RAM, OS SSD and Sata3 Audio SSD, macOS Mojave, PT Ultimate 2021.10, DAPS 3.7.1 HDX2, MTRX Studio & DAD MOM, HD I/O 16x16, Apogee AD/DA 16X/X-HD and ICON D-Command ES. |
Have you tried the eSATA external drives with a eSATA pug in cad?
Dick Maitland C.A.S. |
I don't have room for an extra card.
Glyph external firewire or Internal Sata 11 for recording | mal777 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-13-2008 11:35 PM |
Recording to internal sata or external firewire drive? | Mcgrathx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-28-2008 09:50 PM |
Internal SATA or external FW? | test tube AUDIO | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-03-2007 10:13 PM |
Internal SATA or External USB? (Hard Drives) | lowoctave | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-06-2007 05:11 AM |
second internal drive versus another firewire | Jepse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-02-2005 04:12 PM |
