Old 10-10-2005, 10:40 PM
headclouds headclouds is offline
Default Crackling and noise
All of a sudden i have to lower the volume on all my files. The signal seems to be hot, so much so that i have to lower all tracks so it wont distort, all tracks including the midi tracks?? all of a sudden everything is too loud. i havent done anything and i do not use illegal software! all files new AND old. songs i have finished and mixed with all the levels perfectly how i want them...are suddenly too hot from one day to the next. i have even tried reformatting my compuetr and nothing helps. can it be my 002r? im using 6.9
Dell dimension 8300
win xp home
3.0 ghz
1 gb
Old 10-11-2005, 08:48 AM
Default Re: Crackling and noise
I would be checking your monitors and cables first. Also, if you run a master fader, check to see if it is moved(and if any master plugins have changed settings).
Old 10-11-2005, 12:18 PM
its not the cables cuz i get the noise thru the headphones too. and the plugins..its the same ones ive used for the last 2 years. and that includes using them throughout updates and all. i think its the 002r or maybe the drivers. cuz i still havent installed all the plugins and im getting this problem. as long as i turn down all track levels (midi and audio) its ok. the outgoing signals are way too hot all of a sudden. input signals r normal tho.
Crackling noise in playback mysg4ever Pro Tools SE and Essential (Win) 2 07-08-2014 08:38 PM
Crackling Noise larsongs Pro Tools 10 3 10-16-2012 11:03 PM
Crackling Noise on Playback... of anything itspangler macOS 6 09-04-2012 06:43 PM
Crackling Noise shebil Pro Tools SE and Essential (Win) 2 01-05-2012 11:00 PM
crackling noise beright macOS 1 01-23-2011 03:46 PM
