  #51
Old 12-04-2009, 02:49 AM
olek olek is offline
Default Re: Win7 + HD 8.0.1
Never heared about that kind of trouble.
Maybe switching your Bios to Pluy and Play -ability might help.
What Mobo do you use and how are the slots placed?
In earlier days grafic cards sometimes interfered with Digicards.
If not. A reinstalling of Win7 with card already plug would be my choice.
Not that fast one ... I know.
PT 8.0.1cs1 HD2
Win7 x64 ... running fine with most plugs
WinXP Pro SP2 ... the old cow
Mobo ASUS P5WDG2 WS Pro
Intel [email protected]
8GB Kingston xtreme memory
  #52
Old 12-04-2009, 10:16 AM
Paul S-Tone Paul S-Tone is offline
Originally Posted by DaV- View Post
Hi everyone,
I'm experiencing a major problem in making PTHD working on Win7:
I installed Win7 PRO, without any PT device plugged (Accel card PCIe), and everything goes right. Yeepee...
Now, when I plug the Accel card PCIe and I restart the computer, Windows 7 launches and crashes (freeze on desktop just opened)
Any idea?
iLok is plugged, but I don't think it can have any kind of influence on the processes.
Duno what happens.
DaV-
Hi DAV , it is know issue for me .. HD PCIe cards with Windows 7 and some motherboards that shared PCIe 1X into Intel ICH10 southbridge want not work ..
in this case when you power on , windows7 completely freeze and crash .
I have tryed any sort of setting , tips and tricks but nothing help ...
so i confirm the issue with both Windows 7 32 or 64 !
Which Mobo you have ?
MacPro PTHD 3 PCIe
Protools Lovers
  #53
Old 12-05-2009, 11:52 AM
DaV- DaV- is offline
I use MoBo ASUS P5E.
Paul, are you telling me there is no solution!
  #54
Old 12-05-2009, 12:57 PM
Hi , your mobo is similar to mine ..
unfortunately i think you have my same problem , when plug the cards
into PCIe 1X win7 freeze first or before install the drivers LOL , therefore no way ... , the only solution is to plug the Core Card into the other down 16X blue slot for optain an HD1 .
if you need more than HD1 system , the others solutions it is to change motherboard , i have test the amd's 790fx mobo (borrowed a friend)with n°3 PCIe 1X and work all also with HD3 PCIe .
another alternative it is to go with asus P6T6 i7 soket ; i see here (in the DUC) a topic regarding this mobo seems work with sucessfull .
So we need a motherboard whitout bridge to bridge chipset to share PCiexpress !
Conclusion Windows 7 is like Vista and worse for manage the hardware ( with my mobo and Windows Vista i have install hd3 pci-e , but with much much difficulty , must to plug one card for time or vista freeze like win7 , unfortunately this trikcs no help with win7 )
personally i think to back with Mac very soon !!
MacPro PTHD 3 PCIe
Protools Lovers
  #55
Old 12-05-2009, 06:25 PM
The difference between PCIe 1X & 16X is speed. which ratio is it? If it can be a working solution, I'll go with this one.
Thx very much for your expertise Paul.
  #56
Old 12-06-2009, 12:47 AM
yep is speed , you can plug the card 1x in the 16x slot whitout problem .
Whit your and mine motherboard the PCIe 16 X it is shared directly in the P45 chipset , while the PCIe 1X lines it is shared in the southbridge ICH10 .
so windows 7 cannot manage 1x slots into southbridge with HD pcie cards !
(it completely freeze) .
ciao !
MacPro PTHD 3 PCIe
Protools Lovers
  #57
Old 12-06-2009, 03:25 PM
OK Thx, I'm gonna give a try with this method. I will report here how it works.
Another question: Could I hope some MoBo firmware update will solve the problem or no way?
  #58
Old 12-07-2009, 04:10 AM
with my mobo no help bios update .
try with your mobo .
ciao .
MacPro PTHD 3 PCIe
Protools Lovers
  #59
Old 12-07-2009, 04:41 PM
OK, I tried it today.
- I plugged PCIe accel core card un PCIe 16X (blue slot) = freeze windows at start, exactly the same as PCIe 1X, during driver installation.
- So, I upgraded my BIOS from version 0402 to 1201 (wow, almost 2 years since last update). Nothing better. I also retried PCIe 1X with this BIOS, nothing.
Well, my last lead is to install ProTools HD 8 (with the drivers for Accel card) then plug the card. Maybe in that order, driver installation won't make my PC freeze. What do you think?
  #60
Old 12-10-2009, 01:19 AM
PierrevC PierrevC is offline
Hi guys,
I had the same problem. Not shure about the Mobo I have a dell xps420 but I installed the cards in the wrong order and it solved my problem...
When I checked in the windows device manager pcie slot3 was actually marked as port 4 and slot 4>port3.
Has anyone been able to use an avid mojo in W7? drivers don't seem to be working here
Hope this helps,
Pierre
mac pro 1.1 for 64 bit win7/hdx klaukholm Pro Tools HDX & HD Native Systems (Win) 6 12-11-2013 12:41 PM
Here goes nothing - Bye Bye XP, hello Win7 markus44uk Windows 17 10-02-2011 07:51 AM
big BUG in PT8.03 under win7 X64 32768 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-05-2010 03:47 PM
Win7? Fullsound Recording Pro Tools TDM Systems (Win) 10 04-30-2010 09:44 AM
GR4 PT 8.0.1 Win7 jazzmandan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-01-2009 06:19 PM
