how to disable hyper threading in bios
hi, i'm new at duc, and i get a digi002r and i wonder if someone know how to disable hyper threading in bios because my pc is pentium4 HT.
thanks for your answers, and excuse my english because i'm from southamericas and i speak spanish better |
Re: how to disable hyper threading in bios
Hold down the delete key as you power up your PC. then you need to go the the cpu config (something like that) menu and disable it.
Puedes preguntar todo lo que quieras en español sientras a "los que hablamos español". Buscalo en este mismo espacio en la parte de arriba. OK
Camilo Toledo |
If you have a PC, hit F2 when it's booting, that will get you into the BIOS, from there you can disable hyperthreading, I have a dell, and hyperthreading is off by default, so it's prob a non-issue anyhow, but good to check out when tweaking your system to run PT...
How to disable hyper threading? | bonzerboy | General Discussion | 9 | 09-21-2010 07:11 AM |
disable hyper threading do you have to? | bonzerboy | General Discussion | 0 | 09-20-2010 03:03 AM |
Upgrade from 6.8 to 7 9 Hyper -threading /BIOS) - | songcomposer | Pro Tools M-Powered (Win) | 4 | 07-31-2006 08:31 AM |
How to Disable Hyper-Threading | SKDontPlay | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-23-2005 09:08 PM |
SHOULD I DISABLE MY HYPER THREADING? | METAFOR | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 06-04-2004 03:34 PM |
