Old 05-10-2003, 05:22 PM
donmr123 donmr123 is offline
Default Core Audio 1.2 Reason 2.5, Live! don\'t work!
It seems I'm not the only one with this problem. Reason 2.5 and Ableton Live! don't work with the new core audio drivers v1.2 as advertised. However, iTunes 4 and Quicktime seems to work just fine. In the audio/midi app in OSX with the MBox selected you get a choice between 44.1k and 48k at 32bit!?!?!?
Older versions of core audio driver worked at least with Live! but were too buggy to use. if anyone has any idea how to get Reason 2.5 and/or Live! working with the new CA 1.2 drivers please let us know!
Thanks
Don
Old 05-10-2003, 06:09 PM
Slim Shady Slim Shady is offline
Default Re: Core Audio 1.2 Reason 2.5, Live! don\'t work!
Hey there, just dug out my reason disks so I could authorize and try out 2.5 and you're right, the Core Audio drivers don't work!! There's not even an option for digidesign hardware in the audio preferences panel!
I've got an Mbox on 10.2.5 here, the Core Audio drivers have been working great in Logic Audio 6 since the first revision, but apparently Reason is still a no-go situation.
Old 05-10-2003, 06:30 PM
Philo Philo is offline
You have to use Audio MIDI setup to set the "Default Output" under Audio Devices to the Digi 001. (I kept the system output on Built in).
I restarted, and then the 001 output appeared as an option in Reason 2.5
This is working for me.
Old 05-10-2003, 06:54 PM
Thanks Philo, that totally worked for me too. That's weird that you have to restart - my other audio apps just see the core audio driver without having to have them selected in Audio/MIDI setup. I was even able to reset my default output back to 'built in' one Reason had been launched once with the new setting, just needed to do exactly as you explained to get it working.
Slim
TiBook 1Ghz / 1gb RAM
10.2.5 / Mbox
Old 05-10-2003, 07:11 PM
J. Guerrero J. Guerrero is offline
It's weird what's happening to you, guys.
Again, I'm happy that the driver worked as it's supposed to be with Reason 2.5, without having to select it at either AudioMIDI Setup or the Sound Preference pane. Reason 2.5 just picked it up!
I'm not happy about the buffer size, but it's usable enough to do live performances.
Now, I'm not saying that there's no way that you have problems, something is affecting your system somehow. Do you guys use your computers for tasks other than audio and maybe normal internet usage (check mails, updates, DUC around)...? Maybe that's what is affecting your systems.
Old 05-10-2003, 09:07 PM
kris whitten kris whitten is offline
Anyone care to comment on the new "effects" in Reason 2.5? Are they good, crappy, anything?
Old 05-10-2003, 11:28 PM
Still the same problem. Reason and Live just won't see the MBox. Quicktime and iTunes no problem.
Any other suggestions?
I don't have any apps running that want the sound output as far as I can tell.
This is driving me nuts!
thanks
Don
Old 05-11-2003, 12:45 AM
might there be some kind of preference file I could trash for the audio/midi app in OSX similar to the old routine in OS 9?
Thanks
Don
Old 05-11-2003, 02:20 PM
allisvanity allisvanity is offline
No problem for me either. Reason 2.5 works fine. However, I can't run Reason AND PT at the same time with CA 1.2. Which kinda sucks.
Evan
Old 05-11-2003, 04:52 PM
yes yes is offline
Reason 2.5 is Great! The new reverb is very smooth and flexible. Much better then the old one. The Screamer is cool. Great tape saturation and warmth.
I love it.
Cheers,
Jamie
http://www.strayvoltage.net
Pcie core + Core audio + Tiger, does it work? fantomaz Pro Tools TDM Systems (Mac) 0 12-21-2005 01:04 PM
LE 6.7, Live and Reason - how to manage work flow Ignatius Reilly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-17-2005 11:06 AM
Making work Reason 2 with Core Audio drivers: J. Guerrero 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-04-2003 12:17 AM
Core Audio X: Live & PT sharing audio interface? ashdot Pro Tools TDM Systems (Mac) 1 04-03-2003 10:59 AM
Does anyknow if a Lexicon Core 2 will work with Reason? ckerian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 54 03-26-2002 12:30 AM
