Old 10-01-2009, 09:45 AM
LincolnT LincolnT is offline
Default Hot swapping FireWire MBox 2 Pro
I have heard that hot swapping digidesign firewire interfaces can be bad.
Does it hurt the hardware? or is it just incompatible with the software or drivers or operating system?
Because when installing Pro Tools, messages pop up about unplugging and connecting the Digidesign hardware so that the drivers can install correctly.
I have assumed the risk was only with powered firewire ports. Since I am using unpowered firewire ports with the help of the MBox 2 Pro's power supply, I occasionally unplug the MBox 2 Pro's power supply when the computer is on, and I have had no trouble. Is this procedure ok?
MBox 2 Pro connected to motherboard 4 pin firewire port
Dell Inspiron 9300 laptop
2.0 gHz Pentium M
2 gB ram
Lacie Rugged 5400 rpm firewire 800 on Siig Cardbus adapter
Roland 700SX stage piano
Studio Projects C3 mics
Melodyne Plugin
Dual Boot:
PTLE 8.0.1 on Windows 7 Enterprise 32 bit
PTLE 8.0.1 on XP Media Center SP3
Old 10-01-2009, 09:57 AM
TOM@METRO's Avatar
Default Re: Hot swapping FireWire MBox 2 Pro
The hot swapping damage is usually to the Digi firewire interface. I have never unplugged for installation, I have used the power button on the interface. This may be a taboo (I don't know) but it has never failed me here.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.6 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 10-01-2009, 09:59 AM
Ok, but is it "cold" swapping if I unplug the power supply before unplugging the unpowered firewire cable?
2.0 gHz Pentium M
2 gB ram
Melodyne Plugin
Dual Boot:
Old 10-01-2009, 10:08 AM
sw rec sw rec is offline
Turn off EVERYTHING before you plug/unplug a firewire cable.
Old 10-01-2009, 10:12 AM
Then what is Digidesign's recommendation for people with the MBox 2 Pro and a powered firewire port? Sometimes the Digidesign installation of drivers requires some sort of disconnect/reconnect.
2.0 gHz Pentium M
2 gB ram
Melodyne Plugin
Dual Boot:
Old 10-01-2009, 10:14 AM
Yep, at least in the case of my 002 rack, when it says "disconnect" I turn it off.
When it says "connect your hardware" I turn it back on......just like Tom.
Old 10-01-2009, 10:16 AM
TOM@METRO's Avatar
I am in no way suggesting that you unplug the firewire cable with any devices (including the computer) powered up. The method I used (but do not support) does not involve the unplugging of the firewire at all.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 10-01-2009, 10:21 AM
Unfortunately, there is no power switch on the bus powered MBox 2 Pro.
2.0 gHz Pentium M
2 gB ram
Melodyne Plugin
Dual Boot:
Old 10-01-2009, 10:23 AM
Hmmmm....might be a good time to give tech support a call. I'd like to know the answer to that one too...if ya can't hot-swap without frying FW controllers, how do they expect you to "disconnect/reconnect" hardware at setup?
Old 10-01-2009, 10:50 AM
rqstudio rqstudio is offline
Where I come from "disconnect/reconnect" are not the same as turn the unit "on/off" I actually do it quite a bit on my laptop, (w/mini, micro and Ilok/USB) but then again, I like to live on the edge! For some reason I wouldn't attempt it on my desktop puter/003, don't know why, maybe it's the firewire, maybe it because the units need more juice to power up...(Unless your daring as we are, don't try this at home)
Swapping Mbox 1 to Mbox 2 - straight swap RWTV 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-05-2009 12:36 PM
swapping out my C: drive...? K.B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 30 05-01-2007 11:25 AM
Swapping out PC Soulsanctu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-07-2005 07:12 PM
Swapping Mbox and 002R problems musiqtech 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-18-2005 10:13 AM
Hot swapping the 001 QuikDraw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-06-2005 02:22 PM
