Swapping Mbox 1 to Mbox 2 - straight swap
Hi there,
My Mbox 1 recently packed up - I need the SPDIF ports and something went wrong with them. I just bought an Mbox 2 and I want to swap the physical hardware over without changing ANY of the software.. I don't want PT 8 on my computer - everything works just perfect under PT 7 that I already have installed. My question is: how do I swap over the Mbox 1 to the Mbox 2 without any software changes.. I suppose it needs the new drivers but I wanted to check. I already plugged everything in and it doesn't work.. |
Re: Swapping Mbox 1 to Mbox 2 - straight swap
Quick question.
Why not use the brand new Mbox 2 and avoid the risk of having 2 broken Mboxes, instead of just 1?
Jon HP Pavilion P6000, AMD Athlon II X2 240 (2.8GHz), FOXCONN 2AB1 MoBo, 16GB DDR3, NVIDIA GeForce 8400GS, Two WD Caviar Black Internal500 gig, One WD External 300 Gig, Windows 7 Ultimate 64-Bit, SD2, Metal Foundry, Focusrite Saffire 6, PT 9.03 (stable), Gibson Les Paul Studio (Drop D), Fender Tele (nashville tuning), hand built Carvin Bolt (finished!) |
Yes I want to use the new Mbox 2 but with the Pro Tools version 7 I already have installed... I just don't want to update to PT8 as my setup works fine and I hear stories of people having issues when they update their PT version. I literally want to unplug the Mbox 1 from my USB and plugin the Mbox 2... but whats the best way to go about this?
Ah...my bad. I thought when you said "swap the physical hardware" that you wanted to open up the Mbox 2 and replace the inputs with the previous ones, or some crazy situation like that. My bad. According to the digisite's compatibility grid, you should be able to run 7 on an Mbox 2. Have you tried updating your drivers?
Ah yes! Thanks dude.... I suppose I was looking if there's a way that I should be doing it from the included dsics.... but I have indeed gone to the updates and drivers section of the Digi website and found the relevent drivers..... so far so good! I think it's all working.
Keep us posted. Glad to hear I could have been semi-helpful!
Signal runs straight through Mbox 2 mini/FastTrack | lokimojo | macOS | 20 | 06-04-2013 06:30 AM |
Swap Mbox 3 for 11R | giantkiller | Tips & Tricks | 1 | 02-24-2012 09:19 PM |
Hot swapping FireWire MBox 2 Pro | LincolnT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 09-02-2011 07:20 PM |
Let me get this straight, do NOT power an mbox 2 pro from it's power adaptor? | BGMusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 17 | 12-23-2009 03:45 PM |
Swapping Mbox and 002R problems | musiqtech | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-18-2005 10:13 AM |
