Old 01-27-2009, 06:05 AM
THE STATIC FACTORY THE STATIC FACTORY is offline
Default Midi protools settings
I just recently set my stuio back up and I'm having a problem with tracking out my music. I'm not sure if it's somethin minor like a setting or etc.. This is what i have..
Roland fantom board sync to mpc 1000
mpc midi going into mbox 2.
When I put track into record mode, and started to record it, the sound in the Board would change to a diffrent sound. I've never had this problem in the past. Any suggestions? Could you tell me what settings should be in protools? And also how I should have Board and mpc set up?
Old 01-31-2009, 08:56 AM
ProducerSolo ProducerSolo is offline
Default Re: Midi protools settings
same problem here.. mpc1000 and motif xs.. and i only get one track to work.. when i try to do 2a or a new track it will play all midi data on the mpc..
Old 01-31-2009, 02:13 PM
louielou louielou is offline
might want to turn off all extra midi options like "program change, bank change, etc." in all your devices and protools.
Old 02-08-2009, 09:23 PM
newproducer newproducer is offline
New to this. Any advice on how I should set-up midi with my Pro tools 8 LE MBox 2 Pro, Yamaha XS7, and Macbook Pro?
Old 02-11-2009, 04:45 AM
rudyrhythmz rudyrhythmz is offline
i had the same problem with the triton studio
i fixed it by changing the clock back to internal when it was on external the patches would change back to the initial patch
M-Audio Venom not listed in Midi Settings ProTools LE 8 lupodwdm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 20 04-22-2011 12:03 AM
Protools Settings - Tutorial jmlm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-01-2010 10:30 AM
ProTools, Mac Pro, RTAS settings rtcstudio Pro Tools TDM Systems (Mac) 2 12-05-2008 01:23 PM
looking for plug in settings for ProTools EQ etc rtm Tips & Tricks 5 07-18-2005 12:56 AM
Cubase -Protools settings ---HELP HELP!!!!!!!!! Peter Martin Tips & Tricks 2 02-05-2000 05:32 PM
