More Missing Audio Files that won't relink
Hi! As I’m sure many others do, often I’ve been moving projects between the studio and my home rig on a portable usb drive. For some reason, I’d estimate at least half of the time, when I transfer to and open the project on my home rig, there are missing audio files of the omf variety. The weird thing is that in the relinking window, the path that is listed, is the original audio files folder within the Project folder on the Studio rig. It’s like the project now doesn’t know that the files now exist in the copied audio files folder. Anyway I have no luck relinking the files even with the option "File name" selected and "file type, duration and mod date" deselected. The omf files originated from Premiere. My studio rig is 12.8 os 10.10.5 and my home rig is 12.4 on os 10.10.5. Anyone have any insight?
Thanks, Dan |
Re: More Missing Audio Files that won't relink
When I import an OMF or AAF, I almost always choose 'Copy from source media,' instead of link. I have better linkage and fewer problems this way. If you have done that, try the exact same drive name. Also trash Workspaces so PT refreshes its knowledge of available drives.
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn |
When exchanging sessions between different computers (especially with different versions of PT), things go wrong when opening up PT sessions, that imported audio linked to media from an embedded OMF/AAF file. Relinks don't work anymore etc. You would think that in 2018 Avid would have brought PT and MC closer to each other on the file management level (that is PT closer to MC! dare I say AudioVision 1996 , but apparently it must be a gigantic task to implement. MC has always a perfect idea of its media, even if it's offline and MC lets the user organise media in bins etc . PT doesn't know a lot of its media unless it's online (and getting it online via relink is sometimes not easy, so you have to avoid the pitfalls) and the cliplist can...not be organised by the user PT has made a lot of progress the last few years, but in this department there's certainly room for improvement. Greetings, Thierry
http://www.a-sound.com/ |
Unfortunately, upgrading the home rig to 12.8 isn't a viable option from a financial standpoint. Dan |
I use consolidate on import 6000ms handles. Never have an issue. The problem I believe is in the file names with certain odd characters.
I find copy media is a better solution than ‘force to target’.
‘Force to’ will only convert files that differ from the project settings, copy will move everything. I’ve had issues where I’ve done a force to in the past and then the OMF wasn’t moved with the session and some files had to be relinked, with the copy files selection everything is moved, and it’ll convert the audio if needed, and it’s my preferred option all around. |
How do you get missing audio files to Relink? | DJ Hellfire | Pro Tools 12 | 3 | 03-13-2017 12:43 AM |
Pro Tools 10 missing audio files Relink Problem???? | sebdj | Pro Tools 10 | 5 | 03-13-2014 02:17 PM |
All Sessions using SDII files are missing all audio files and won't relink | bigmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-18-2009 12:54 PM |
Pro Tools LE System- Missing Audio Files/No Relink | Ericka | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-21-2006 04:22 AM |
Missing Audio Files - cant relink? | mikef585 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-15-2005 09:39 AM |
