  #21
Old 07-03-2020, 11:03 AM
Default Re: Pro Tools won't shutdown
Originally Posted by John003 View Post
Here it is 2020 and still no fix for this. Whimpy software can't even shut itself down properly. Nobody's ever seen anything like it.
Still no fix for what exactly? There are folks likely talking about different issues in this thread. With OSes apparently all over the place from Windows 7 to 10. Have you described anywhere what exact problem you see? What version of Pro Tools on what OS. Did you post a Sandra Report? Do you have an Avid support incident number... post it here and that may get more help for you.
For example is Pro Tools hanging while saving a session then exiting or while exiting with no session open. What troubleshooting have you have done?
If there was an generic issue with Pro Tools not shutting down hundreds of people would be screaming about it on DUC and... nope. You likely have a problem very specific to your setup and you have to troubleshoot that.
Obvious things to try are: does the window event log show anything interesting? trash prefs, test starting with empty sessions, temp. remove all plugin files, test with peripherals and control surfaces disconnected, check the system is fully optimized, check that no session content is on anything potentially funky like network or cloud storage (including excluding things like user directories, and pref files, are not trying to use network/cloud storage), uninstall or disabled AV software, try a different audio device, test with the latest version of Pro Tools, spin up a clean Windows install and minimum Pro Tools install and test on that...
  #22
Old 07-03-2020, 12:43 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
I had that problem and updating to the latest version of iLok License Manager solved it.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
  #23
Old 07-06-2020, 09:40 AM
Benoni's Avatar
Benoni Benoni is offline
Did a video on this awhile back
FIXED - Pro Tools Automatically Re-Opens After Closing
https://youtu.be/Z3VPA9Ny1EM
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Pro Tools freezes on shutdown or when importing files Old School Audio Guy Windows 1 12-29-2012 10:54 PM
when i launnch pro tools my computer says it needs to shutdown melchiorre 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-02-2011 01:22 PM
I shutdown pro tools 9 le I get this access violation! shamanrock Pro Tools 9 1 11-13-2010 09:21 PM
spontaneous shutdown pro tools 8 parlour snake 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-13-2010 06:33 PM
shutdown error with pro tools on xp chairmanblow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-02-2007 07:34 AM
