Old 02-04-2012, 07:14 PM
pilipinokuno pilipinokuno is offline
Exclamation "Hardware controls for this peripheral are handled in its Setup Application"
This is the only text visible when I click on Hardware under the SetUp Tab: "Hardware controls for this peripheral are handled in its Setup Application"
If you could explain what I am doing wrong, pls offer a hand.
System: Windows 7 64-bit Toshiba Laptop
Hardware: Pro Tools MP9; MobilePre 2nd version
Old 02-05-2012, 05:50 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: "Hardware controls for this peripheral are handled in its Setup Application"
Do you have this version of drivers installed?
http://www.m-audio.com/index.php?do=...92&OS=x91#tabs
The MobilePre USB’s Windows Multimedia drivers will allow you to use the MobilePre USB as your Windows system sound device. If the MobilePre USB is the only audio device installed in your computer, then Windows will “select” it automatically. Otherwise, you may need to tell Windows to use the MobilePre USB.
To check your Windows Audio setting and select the MobilePre USB: Control Panel>Sound>Playback Tab>the default device should say “MobilePre USB.” If it does not say MobilePre USB, then drop down the list of devices and select “MobilePre USB” as Default.
You should see an M-Audio logo “M” installed on the right side of your Windows taskbar. Double click on this logo, to launch the MAudio MobilePre USB Control Panel.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
[IMG] code is Off
"Hardware controls for this peripheral are handled in its Setup Application" pilipinokuno Pro Tools M-Powered (Win) 1 02-07-2012 03:57 AM
"Hardware controls for this peripheral are handled in its Setup Applic pilipinokuno Pro Tools M-Powered (Mac) 1 02-04-2012 07:53 PM
"Digidesign" Folder not shown in "Application Support" jollyboss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-01-2012 02:12 AM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
Don't see "Hardware Setup Sync"...... Mike Teezie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-21-2002 02:36 PM
