Reason rewire not working in PT12
Hiya,
I recently upgraded into a brand new MacBook Pro with al the trimmings. I used to use PT10 with Reason 5 (and before that PT 8, 7, 6 etc and Reason 3) with multiple reason audio channels coming into sessions, driven by midi from PT. I now have PT12 and Reason 8 in Yosemite. Reason does not come up in my instruments list in the PT inserts. Waves rewire does come up, so Rewire must be working to some degree. Reason comes up beautifully as a fully-functioning rewire companion to Ableton Live 9 ... so Rewire must be working from Reason's end of things. I have read of numerous instances of Reason/PT rewire difficulties on this forum, but the symptoms seem to be different to mine. Can anyone help me here? I assume that both PT12 and reason 8 are 64-bit, so there should be no incompatibility there. Many postings suggest opening the "get info" window on the Reason app icon and forcing a bit depth. I get no such options. Is there something missing? Any suggestions will be received with deep gratitude. thanks Andy Maleny Queensland |
Re: Reason rewire not working in PT12
Yes PT12 and Reason are 64 bit but Reason has to be set to run as 64 bit. The Mac version of Reason actually has both 32 and 64 bit support from the same install. With Reason closed right click on the Reason icon and select 'get info'. When that window opens check for the state of the checkbox that selects whether Reason runs as 32 or 64 bit and make sure it's set to run as 64 bit. Do this and you should be good to go.
Word of warning: I don't have PT12 but PT10 and PT11 but when I use Reason rewired into PT AND I'm using a patch in Reason that has a Combinator I can't use a single MIDI path into Reason. I have to use two - one for MIDI cc7 (volume) and a second for everything else MIDI. This is with Reason 7 and maybe they fixed this in R8. If I don't use a Combinator in Reason only a single MIDI path is needed between the two programs. |
It's also a known issue that newly installed Rewire apps won't show up in Pro Tools until the plugin cache is trashed and Pro Tools has to scan a rebuild it.
Follow the instructions for 11, it's the same with 12. http://www.sweetwater.com/sweetcare/...s-preferences/
Wonder if this version of Reason doesn't work in OSX 10.13.3
PT Ultimate 2023.06, Mac Studio Max M2 64GB RAM, HDX, OSX 13.04.01, EuControl 2023.06 w/ Avid S1 |
That could well be it. Reason 8 is way old. You're going to have to upgrade to Reason 10.
Rewire Reason 6.51 to PT9 not working? | lwilliam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-30-2012 11:52 PM |
Reason 4 + 002 not working in Rewire mode. | DJ Hellfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 31 | 08-23-2010 12:25 PM |
Pro Tools LE and Reason 4 w/ Rewire not working. | cringe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-12-2008 01:28 PM |
Reason/REWIRE not working in PT 6.1.2 | thumbolt68 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-19-2006 02:21 PM |
Reason working in standalone, but not with ReWire. | pedrohead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 11-19-2003 05:56 AM |
