Pro Tools 11 Saving Freezes for 30 seconds
Hello,
I am running Pro tools 11.2.2 on Windows 7 with 8 Core i7 16 GB Ram, 10 TB or storage. I never had this issue with any previous versions of Pro Tools. When a hit Save, it doesn't matter is I click it or Control+S or when the Auto Save occurs, it locks up Pro tools for approximately 30 seconds. It previous versions this did not occurs. Is this happening to anyone else? Does anyone know how to correct it? Attached is a Sandra report. SiSoftware Sandra ID Host Name : pc-PC Workgroup : WORKGROUP Computer Model : OEM System Product Name Serial Number : System Ser********** Chassis : Desktop Mainboard : ASUS P8P67 PRO Serial Number : MT700BK******** BIOS : AMI (OEM) 2001 09/20/2011 Total Memory : 16GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz (4C 8T 4.43GHz/6.08GHz, 4.43GHz IMC, 4x 256kB L2, 8MB L3) Socket/Slot : FC LGA1155 Chipset Memory Controller : ASUS Core (Sandy Bridge) DRAM Controller 103MHz, 2x 8GB DIMM DDR3 1.65GHz/1.33GHz 128-bit Memory Module(s) Memory Module : Corsair CML16GX3M4A1600C9 4GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CML16GX3M4A1600C9 4GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CML16GX3M4A1600C9 4GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CML16GX3M4A1600C9 4GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Video System Monitor/Panel : Samsung SyncMaster (1600x1200, 19.1") Monitor/Panel : Samsung SyncMaster (1600x1200, 19.1") Video Adapter : NVIDIA GeForce GT 430 (SM5.0, 2GB) Graphics Processor Compute Shader Processor : NVIDIA GeForce GT 430 (2GB) Storage Devices Crucial M4-CT128M4SSD2 (128GB, SATA600, 2.5", SSD) : 119GB (C WDC WD1001FALS-00J7B1 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (F WDC WD10EZEX-00KUWA0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (D Seagate ST9500325AS (500.1GB, USB2/SATA150, 2.5", 5400rpm, 8MB Cache) : 466GB (L (M Seagate ST3500418AS (500.1GB, USB2/SATA300, 3.5", 7200rpm, 16MB Cache) : 466GB (J WDC WD5000AADS-11M2B2 (499.4GB, USB2/SATA300, 3.5", 32MB Cache) : 465GB (H Seagate ST31000528AS (1TB, USB2/SATA300, 3.5", 7200rpm) : 932GB (I Seagate ST3500320AS (500.1GB, USB2/SATA300, 3.5", 7200rpm) : 466GB (K HL-DT-ST DVDRAM GH24NSB0 (SATA150, DVD+-RW, CD-RW, 512kB Cache) : N/A (E WD Virtual CD 1110 (700.4MB, USB2) : 668MB (G Logical Storage Devices System Reserved : 100MB (NTFS) AudioData (F : 932GB (NTFS) @ WDC WD1001FALS-00J7B1 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) Audio Data New (D : 932GB (NTFS) @ WDC WD10EZEX-00KUWA0 (1TB, SATA600, 3.5", 7200rpm) NEW VOLUME (L : 12GB (FAT32) @ Seagate ST9500325AS (500.1GB, USB2/SATA150, 2.5", 5400rpm, 8MB Cache) Hard Disk (J : 466GB (exFAT) @ Seagate ST3500418AS (500.1GB, USB2/SATA300, 3.5", 7200rpm, 16MB Cache) Audio Archives (H : 465GB (NTFS) @ WDC WD5000AADS-11M2B2 (499.4GB, USB2/SATA300, 3.5", 32MB Cache) Backup Audio Files (I : 932GB (NTFS) @ Seagate ST31000528AS (1TB, USB2/SATA300, 3.5", 7200rpm) Backup Programs and MP3 (K : 466GB (NTFS) @ Seagate ST3500320AS (500.1GB, USB2/SATA300, 3.5", 7200rpm) Programs and MP3s (M : 454GB (NTFS) @ Seagate ST9500325AS (500.1GB, USB2/SATA150, 2.5", 5400rpm, 8MB Cache) Hard Disk (C : 119GB (NTFS) @ Crucial M4-CT128M4SSD2 (128GB, SATA600, 2.5", SSD) Optical Drive (E : N/A @ HL-DT-ST DVDRAM GH24NSB0 (SATA150, DVD+-RW, CD-RW, 512kB Cache) WD SmartWare (G : 443MB (UDF) @ WD Virtual CD 1110 (700.4MB, USB2) Peripherals LPC Hub Controller 1 : ASUS P67 LPC Controller LPC Legacy Controller 1 : T0 C3-33 Audio Device : ASUS Cougar Point High Definition Audio Controller Audio Device : PNY GF108 High Definition Audio Controller Audio Codec : nVidia 0014 Audio Codec : 1 0001 Audio Codec : 1 0001 Serial Port(s) : 1 Disk Controller : ASUS Cougar Point 6 port SATA AHCI Controller Disk Controller : ASUS JMB362 AHCI Controller Disk Controller : ASUS 88SE9120 SATA-600 Controller USB Controller 1 : ASUS Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : ASUS Cougar Point USB Enhanced Host Controller #1 USB Controller 3 : ASUS Renesas Electronics USB 3.0 Host Controller USB Controller 4 : ASUS Renesas Electronics USB 3.0 Host Controller FireWire/1394 Controller 1 : ASUS VIA VT6308 1394 OHCI Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Remote Desktop Easy Print (600x600, Colour) Printer : Remote Desktop Easy Print (600x600, Colour) Printer : Remote Desktop Easy Print (600x600, Colour) Printer : Remote Desktop Easy Print (200x200) Printer : Remote Desktop Easy Print (4000x4000, Colour) Printer : Remote Desktop Easy Print (600x600, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Intel(R) 82579V Gigabit Network Connection (Ethernet, 1Gbps) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 5.7 |
Re: Pro Tools 11 Saving Freezes for 30 seconds
When you boot into BIOS, is there a floppy drive listed anywhere? If there is, disable it and try PT again.
Make sure that the sessions you're opening (and any other PT-related media) are NOT stored on your H: or J: drive, as those are both "green" hard disks.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
I will check the BIOS tonight. I can't imagine there would be a floppy disc in the bios as the Motherboard only has SATA connections and does not contain a floppy connection.
For the drive description. Crucial M4-CT128M4SSD2 (128GB, SATA600, 2.5", SSD) : 119GB - USED FOR WINDOWS WDC WD1001FALS-00J7B1 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB INTERNAL COPY OF AUDIO SESSION DRIVE WDC WD10EZEX-00KUWA0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (D - - AUDIO SESSION DRIVE All the other drives are rotated for Offsite backup. |
Right, I read the drive descriptions before I posted. One of them was "Audio Archives", the other was labeled "Hard Disk".
I'm not looking over your shoulder, so I don't know if you maybe opened up a session from the archive disk, or what you happen to keep on the hard disk labeled "hard disk". Sorry, I just realized I made a mistake - only the H: drive is a green drive. Sometimes the BIOS will include a floppy entry, and this can cause trouble for pro tools (no one really knows why, perhaps it is problematic only for those computers with no actual floppy drives)
All sessions or just the one currently in service?
All optimizations done? Especially on the hard drives and the GPU. I had a problem after I upgraded my audio drive to a SSD - a link to my session folder was still pulling up the old session (on the drive, even after I had moved the drive and began using it as a backup drive) ie. Double check your disk allocation
I have opened the audio from the correct drive. This does not occur in Pro-tools 10. I also reloaded the OS 2 times. I start with Windows 7 Ultimate, then reinstalled Windows 7 Ultimate, and now I am running on Windows 7 Enterprise, which is Essentially Ultimate.
I'll check the floppy disk setting. I don't believe I saw that in the optimization guides, but I could be wrong. Other than that, PT 11 has been great. |
Also I have seen plugin cause Issues
If you have the AIR Vi's in the session Cntrl-S when in playback can be a pain.
All Data is written to the drive "Audio Data New" Compression and Indexing is disabled for all drives. Are there additional optimizations that I missed for the HD? Also, there use to be a tool that would optimize your system for PT, though I can no longer find it on the internet. |
I am using the included VI's. Playback is fine. It's when the system is "Saving" or "Saving Backup" that it locks up for 30 seconds.
Have you tried trashing prefs and databases?
Pro Tools 11 hangs every minute or so for 30 seconds | Voice Crafters | macOS | 8 | 04-29-2014 10:24 AM |
Pro Tools frezees on 2 seconds after hit play | anweiss | Pro Tools TDM Systems (Mac) | 3 | 07-19-2010 02:43 AM |
session "freezes" for a few seconds when I hit the record button | Reinaldes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 11-23-2009 07:26 PM |
Pro Tools stalling for 3 seconds on record | TC1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-02-2006 10:44 PM |
6.1 freezes appx 20 seconds into record mode | MrShayne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-03-2003 06:14 AM |
