Latency with UAD-2
Hey all. Just upgraded from a great old ADK workstation to a great new ADK workstation. Running HDN with an Omni under 8.1 Pro. All is running well, except for impossible amounts of latency during recording with any UAD-2 plugins anywhere in the chain. All other native plugins are fine. Is this normal?
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7 |
Re: Latency with UAD-2
Okay, upon further inspection of the specifics and their numbers, it turns out that it's just a case of the UAD-2 plugins introducing far more latency than any of the Waves, Avid, Softube or other plugs I compared them against, and doing a latency click track recording test confirms that the actual number samples of latency shown in the compensation display are indeed added to any recorded tracks. (My base latency with no plugs is about 330 samples)
So the NEW question, since I'm assuming many, many of you are intimately familiar with this issue, is how does everybody deal with this? I use strictly outboard gear during recording, but what if you want to overdub into projects that already have a bunch of latency-inducing plugins instancated? Do you really have to deactivate them all? There must be a better way!
You can use low latency monitoring on the OMNI (only works with AVID interfaces). Bypasses all plugs and sends on record enabled channel but will give you 1.9ms latency at 44.1K or 0.47ms latency at 96K.
2017 27" iMac 3.8GHz i5, 1TB SSD Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB Musician: http://www.ivanlee.net/ Design Engineer: http://www.propowerinc.com/resume.html |
Unfortunately not an option for me, as I need to be able to set up customizable mixes for my talent, and LLM kills the aux sends.
With further testing, I'm getting further confused. If "compensate for input delays after record pass" is checked in my I/O setup, PT will add the cumulative delay compensation amount in the entire project to the recorded files, making them (potentially) wildly late in the timeline. When it's off, I get the normal ADDA amount of latency. Isn't that counter-intuitive?
I use a line split after my outboard pre, one is retuned to the converter the other goes to a smaller mixer for the artist to monitor their que mix off of.
I find the latency annoying as well. I try to put all UAD plugins in the same slot(as in A, B, C, etc) so I can make the entire row inactive for tracking. My template sessions have my usual high-latency plugins in place, with general presets, BUT made inactive. If you only have a few UAD plugins, you can open them, one by one, and click the little microphone symbol near the bottom-left to put the plugin(s) into "live" mode(low latency), but this setting is NOT remembered when you close the session.
Okay, I was mistaken about the "compensate for input delays after record pass" influence. It does nothing at all either way. I did discover that the problem of cumulative delay being added to the recording track only happens if recording is done through a bus. Recording direct to a track through a physical input not only eliminates any added track delay, but also reduces the base sample latency by about 200 samples. Adding live UAD or other high-latency plugs to the recording channel or master output still causes monitoring latency, but doesn't cause recordings to be made out of sync. So overdubbing into heavily mixed projects can work by simply de-activating any high latency plugs on the recording and main out tracks. Whew! Quite a relief. Thanks for all the input, guys.
UAD plugs have 4 buffers to go through:
PT Buffer setting to get out of the Mixer and go to the UAD the Receiving Buffer of the UAD the Output Buffer of the UAD Pro Tools Buffer to get it back into the mixer if you want to track through UAD plugs an UAD Interface is the best option so the plugs can be used before ever getting to Pro Tools
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
I also found it interesting that UAD's per-plugin latency was far lower in PT10 than PT11. Same issues, but smaller amounts. Obviously an engine thing.
Automation latency when using plugins that have long latency | pyrodave | Pro Tools 11 | 2 | 01-27-2014 11:22 AM |
omni/native latency vs mbox pro latency | chrisdee | Pro Tools HDX & HD Native Systems (Win) | 34 | 03-30-2012 07:24 AM |
Latency Issues - changing latency has no effect | Kippa-Dee | Pro Tools M-Powered (Win) | 1 | 07-15-2010 08:39 PM |
Unity DS-1 and Latency... Anyone else feel the latency makes the Plugin unusable? | Mt.Everest | Pro Tools TDM Systems (Mac) | 7 | 08-26-2001 04:53 PM |
New Latency Specs?? (Oh no, not another latency question!!) | gtrboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-05-2000 04:56 AM |
