Old 04-14-2022, 11:10 AM
bifbangpow bifbangpow is offline
Default Unable to record? Weird error mesage
Hi. I'm trying to bus one track to another and record it to audio, but I get an error message that says "Unable to create record files for one or more tracks. Check your disk allocation and drive permissions." I haven't changed my disk allocation or drive permissions, at least not deliberately. What should I do?
my specs:
iMac 2020
3.8Ghz 8-core Intel core i7 processor
Catalina OS
ProTools 2020.12
Scarlett Focusrite
+ Saving to External Harddrive
http://MayMcDonoughMusic.com
Old 04-14-2022, 11:18 AM
hotsizzlemusic hotsizzlemusic is offline
Default Re: Unable to record? Weird error mesage
Just started getting these to pop up on 2021.12 (OS X 10.15.7) as well. Only fix I found was to record to the computers HD, not an external.
Old 04-14-2022, 11:22 AM
im running the same operating system. I opened up workspaces and set record to the mac HardDrive... till wont work.
my specs:
iMac 2020
Catalina OS
ProTools 2020.12
Scarlett Focusrite
Old 04-14-2022, 11:31 AM
copy your session folder or start a new session on the main HD...open it from that location and you should be able to record.
composer
http://frankciampi.com
Old 04-14-2022, 12:18 PM
turns out reversing playback and record in the workstation (making mac playback and external drive record) has somehow saved the day...
my specs:
iMac 2020
Catalina OS
ProTools 2020.12
Scarlett Focusrite
Old 04-14-2022, 11:47 PM
inf0l inf0l is offline
It sounds like a permissions issue on your drive (so not a PT issue per se).
Are you logged in using an Admin or User account?
If you don’t have admin privileges on the machine, you’re only able to write data within your home folder (unless an admin account has setup alternate permissions for the user account).
If you’re indeed logged in as an administrator, I’d run Repair Permissions for the system drive, and then check PT record permissions in workspace.
Unable to record error Aussie John Pro Tools | Intro Discussion 2 12-26-2020 02:13 PM
Error Message when I try to play track. Unable to record mikedoo macOS 1 01-03-2012 02:36 PM
Unable to record due to error CPU Usage warning DagTEK Pro Tools M-Powered (Win) 1 04-07-2008 11:42 AM
error mesage ian perreira 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-02-2006 09:52 AM
error mesage dae -228 danny-a Pro Tools TDM Systems (Mac) 0 09-30-2001 06:32 AM
