Importing MIDI "one note"
It was suggested that importing MIDI drum tracks as "one note" tracks... which I assume means that if there are 8 notes used to determine 8 differnet drums/cymbals (kick, snare, tom, hat open, hat closed, etc) that it would be easier to edit when importing tracks composed on other/older MIDI software.
I've searched the manual to no avail... how does one do this? I'm working with someone who's Midi files unfortunately are not triggering the correct part of the 'kit"... or not triggering anything. Moving the notes to the correct spot is tedious, and in some cases it's just specific 'lines" that need to be moved, not everything within a region as I normally work with living breathing drummers this is new to me (but I see a value to knowing how to work with MIDI files) Thanks for any insight!
Stainless - G5 2.3x2, 5 GB RAM, 1.5TB, OSX 10.5.x and 8.0 002R/D8, MC Control/MC Mix, etc, etc, etc |
Re: Importing MIDI "one note"
'Select/Split Note' to Track apply Track-Based RTP Transpose.
Aaron Mulqueen - 001 HD Native |
I apologize for seeming to be so deficient.... but WTF do you find the option to "split note"?
I select "Import -> Midi" and that doesn't seem to be an option I can find what am I missing?
You would type 'Split Note' in the search function of the Pro Tools Reference Guide .pdf version.
Thank you!
"wait for MIDI note" is not working | montelee | macOS | 3 | 05-08-2015 11:33 PM |
MIDI editor: display note "names"? | mike_mccue | Pro Tools 9 | 5 | 11-12-2012 04:35 AM |
MIDI note Latency . . . live keyboard playing is a "little behind" | The Zone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-09-2012 05:33 PM |
Random "pre-midi notes" before real note | Mahkyb | macOS | 8 | 02-08-2012 06:36 AM |
"waiting for note" or "online" | DMiddlezz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-19-2010 11:31 AM |
