Making Windows 7 more stable?
I recently purchased a very nice laptop running Windows 7 as my main protools computer. I knew that Protools was still in beta for running on Windows 7 but I wanted to give it a shot.
I'm having a bunch of problems. I've gotten the blue screen of death dozens of times in the past few days. Protools will sometimes load flawlessly, sometimes it will crash. I've also experienced crashes when trying to import audio. Melodyne also seems to have problems opening/will crash my computer. What should I do? Anyway to stabalize windows 7? Should I consider switching to XP or Vista? |
Re: Making Windows 7 more stable?
That being said... there may also be some issues with your laptop, as many PC laptops, even "nice" ones, do not meet the requirements for Pro tools. Best bet, is to run through here: http://duc.digidesign.com/showthread.php?t=187759 and then give us a Sandra report.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
Any time you are adding anything to Pro Tools in Windows 7, start Pro Tools as an administrator. Otherwise Windows 7 won't let Pro Tools or it's plugins write configuration files that are needed. After everything is configured, you can start Pro Tools normally.
laurencekingston.bandcamp.com |
Yes, my computer meets all standard requirements. 8 GBs of RAM, 500Gigs storage. I was really hoping this computer would just fly through protools.
When I run protools as an administrator, everything launches fine but Melodyne still crashes. Maybe it is a Melodyne specific problem and I will try reinstalling it. What is a Sandra report? |
I start PT 8 as administrator everytime on Windows 7 64bit ultimate. Works ok. |
Click the link in my post above, and download the "lite" software, and copy/paste the system report into a thread here, and we will have a better idea of whether or not your system is suitable for running Pro Tools. Also, making sure all of your plugins are 100% current and updated is extremely important to stability. If Melodyne is causing problems, it's mostly likely that the version is out of date.
SiSoftware Sandra
Computer Model : Asus G73Jh Workgroup : WORKGROUP Host Name : ChasePC User : Chase Processor Model : Intel(R) Core(TM) i7 CPU Q 720 @ 1.60GHz Speed : 1.85GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Mobile, Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 6MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 8 threads sharing Computer Platform Compliance : Intel Centrino Mobile Technology Mainboard : Asus G73Jh BIOS : AMI G73Jh.206 02/26/2010 Bus(es) : PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 8GB DDR3 SO-DIMM Chipset Model : ASUS Clarksfield/Lynnfield DMI Front Side Bus Speed : 2x 2.56GHz (5.11GHz) Chipset Model : Intel Core Mobile (Clarksfield) UnCore Front Side Bus Speed : 2x 2.27GHz (4.54GHz) Total Memory : 8GB DDR3 SO-DIMM Memory Bus Speed : 2x 710MHz (1.42GHz) Memory Module(s) Memory Module : Kingston ASU1333D3S9DR82G 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Kingston ASU1333D3S9DR82G 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Kingston ASU1333D3S9DR82G 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Kingston ASU1333D3S9DR82G 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Video System Video Adapter : ATI Mobility Radeon HD 5870 (800 SM5.0 700MHz, 1GB DDR5 2x1GHz, PCIe 2.00 x16) Graphics Processor Adapter : ATI Mobility Radeon HD 5870 (800SP 10C 700MHz, 1GB 2x1GHz) Adapter : ATI Mobility Radeon HD 5870 (800SP 700MHz, 1012.2MB 2x1GHz) Storage Devices Seagate ST9500420AS (500.1GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) : 466GB (C:) (D:) Seagate ST31000528AS (1TB, USB/SATA300, 3.5", 7200rpm, NCQ) : 932GB (H:) TSSTcorp CDDVDW TS-L633C (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 8GB (E:) Logical Storage Devices OS (C:) : 116GB (NTFS) @ Seagate ST9500420AS (500.1GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) DATA (D:) : 330GB (NTFS) @ Seagate ST9500420AS (500.1GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) KACZ BACKUP (H:) : 931GB (NTFS) @ Seagate ST31000528AS (1TB, USB/SATA300, 3.5", 7200rpm, NCQ) Pro Tools LE (E:) : 8GB (CDFS) @ TSSTcorp CDDVDW TS-L633C (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS HM55 LPC Interface Controller Audio Device : ASUS P55/PM55/3400 High Definition Audio Audio Codec : Realtek Semiconductor High Definition Audio Audio Device : ASUS EG JUNIPER XT Audio Device [Radeon HD 5700 Series] Audio Codec : ATI (AMD) AA01h Disk Controller : ASUS P55/PM55/3400 4 port SATA AHCI Controller USB Controller 1 : ASUS P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : ASUS P55/PM55/3400 USB2 Enhanced Host Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Atheros AR8131 PCI-E Gigabit Ethernet Controller (NDIS 6.20) Network Adapter : Bluetooth Device (Personal Area Network) Wireless Adapter 1 : Atheros AR9285 Wireless Network Adapter (802.11g (ERP), 54Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 100% Operating System Windows System : Microsoft Windows 7 Home 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 5.9 |
2 Things that I do for stability is in the compatibility tab (right click the short cu, click properties, click compatibility tab. Select "Run program as an administrator" and "Disable desktop composition". Also I would disable your wireless networking. That's known to be problematic.
Edit: I don't know about bluetooth. I disable mine on my laptop just cause I do a lot of mobile live band recording and can't afford problems. |
i adjusted the compatibility tab settings and it seems to crash less. thank you!
i still have problems with it crashing when i try to import audio. Whenever I leave protools on and let my laptop fall asleep, i encounter problems with the protools clock and it will not let me play the song. I have gotten several errors requesting that I increase/decrease H/W settings. Any tips? I'd rather not remove windows 7 from my computer; how hard is it to dual boot XP on a windows 7 machine?? |
What hard drive are you recording too? USB drives are not supported. And a drive partiton is NOT a seperate drive. You need a physical second drive to record to. No usb. Esata, or Firewire with the correct chipset, OR another internal is fine too and prefered. 7200RPM minimum.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Which Windows is the most stable? | JonnyGinese | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 12-05-2005 08:00 AM |
Windows Stable? | Tech_Paul | Digidesign Hardware & Software | 3 | 08-13-2002 02:19 AM |
WINDOWS ME IS STABLE! | fresh_meat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 04-13-2002 10:26 AM |
Windows XP Maybe Stable? | Valve | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-09-2001 04:17 PM |
Windows and Digi001. How stable? | AEW | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-19-2001 07:15 PM |
