Pro Tools 7.4cs3 Updates for all 7.4 Systems
Pro Tools 7.4cs3 updates for all Pro Tools 7.4 systems are vailable for download from the Pro Tools CS Updates page:
www.digidesign.com/support/csupdates And related support sections for Pro Tools 7.4 software and hardware. Downloads & Details Pages for Pro Tools HD & LE 7.4cs3:
Pro Tools HD 7.4cs3 for Mac & Windows Fixed: Surround Pan Automation is not Updating Properly in Loop Playback (Item # 85802) The pan positions are correct on the first play of the selection, but can be incorrect on subsequent plays Fixed: Playback of Surround Panning automation gets "stuck" (Item #100847) This would only occur when writing automation with a selection highlighted while in Loop Playback mode Fixed: Trim Values Could Be Accidentally Written To The Entire Session (Item #100795) Steps to reproduce: - A fader position in Latch/Trim or Touch Trim could be accidentally bumped while the transport was stopped. - Subsequently leaving Trim mode, or manually coalescing trims would then write that bumped value to the entire track Fixed: Pro Tools Automation Thinning Could Sometimes Remove Non-Redundant Breakpoints (Item #100794) The thinning algorithm could mistakenly classify a breakpoint as redundant Fixed: Certain Third Party Products Could Cause Pro Tools to crash (Item #100661) Celemony Melodyne and AudioEase Snapper would cause a crash with tick-based regions (introduced in Pro Tools 7.4) Fixed: Mojo - PAL QuickTime or MXF Movies Could Stutter or Display in Black and White (Item #101047) This resulted from Mojo getting "stuck" in NTSC mode even when Pro Tools was set to PAL Mac Only: Fixed: Scrubbing Avid Video on the Computer Monitor Would Resize the Picture (Item #100657) Pro Tools LE 7.4cs3 for Mac & Windows Fixed: When Monitoring All Inputs on 003 Factory, Random Pops and Clicks Could Occur on Inputs 4-8 (Item #101084) Although this is not likely to occur on 003 Rack, this update is recommended for both 003 Factory (console) and 003 Rack Fixed: Pro Tools Automation Thinning Could Sometimes Remove Non-Redundant Breakpoints (Item #100794) The thinning algorithm could mistakenly classify a breakpoint as redundant Fixed: Certain Third Party Products Could Cause Pro Tools to crash (Item #100661) Celemony Melodyne and AudioEase Snapper would cause a crash with tick-based regions (introduced in Pro Tools 7.4) Fixed: Mojo - PAL QuickTime or MXF Movies Could Stutter or Display in Black and White (Item #101047) This resulted from Mojo getting "stuck" in NTSC mode even when Pro Tools was set to PAL Mac Only: Fixed: Scrubbing Avid Video on the Computer Monitor Would Resize the Picture (Item #100657)
Administrator Avid Pro Audio Community |
Pro Tools 7.4cs3 Updates for all 7.4 Systems | Avid | Technical Alerts | 0 | 03-01-2008 10:15 AM |
Pro Tools 7.4cs2 Updates for all 7.4 Systems | Avid | Post - Surround - Video | 0 | 12-21-2007 02:59 AM |
Pro Tools 7.4cs2 Updates for all 7.4 Systems | Avid | Technical Alerts | 0 | 12-21-2007 01:52 AM |
Pro Tools 7.3.1cs4 Updates for All 7.3.x Systems | Avid | Technical Alerts | 0 | 07-26-2007 09:56 AM |
Pro Tools 7.3.1cs2 Updates for All 7.3.x Systems | Avid | Pro Tools M-Powered (Win) | 0 | 03-09-2007 01:40 AM |
