Old 11-12-2006, 02:18 PM
pezguy pezguy is offline
Default midnam and middev files
I have read the manual regarding the middev and midnam files. The middev seems to be difficult to edit properly. Is there a place to download updated versions of these files? I have an AKAI MPD24 and a M-audio Axion 49 I would like to add to the MIDI Studio setup.
Old 11-12-2006, 06:20 PM
Default Re: midnam and middev files
The .middev files can be obtained from spkguitar's web site. Link
filosofem
Aaron Mulqueen - 001 HD Native
Old 11-12-2006, 06:26 PM
spkguitar's Avatar
They are both controllers only, are they not? Since they have no MIDI patch names to change, you don't need the midnam files. Adding them to MIDI Studio Setup will only make them easier and more recognizable to select, and all you really need to do to make that happen is to create a new device in MIDI Studio setup and give it the proper name.
If you really want to, you can try my Online middev Generator, though it's not really necessary for either of those devices.
Old 11-12-2006, 11:37 PM
You are correct they are both controllers however it is easier for me to read the midi ins and outs with the name of the device instead of just the port name and channel. It just helps my workflow. Thanks so much for the assistance.
Old 12-20-2006, 05:25 PM
jarloose jarloose is offline
i went the link for the middev generator. i found all the values necessary to fill in the blanks except 3. im using a yamaha motif6. i also spoke tech at yamaha and they didnt know what info should go here nor where i could find it. i check the data list and midi implementation charts and i still am at a loss.
i verified these values to be correct with tech, but what about the rest? can you help?
manufacturer: yamaha
model: motif6
can route:????
minimum value:10
maximum vaule:65
default value:????
base value:??????
receives
max channel:16
mtc: yes
clock:yes
transmits
max channel:16
mtc:yes
clock:yes
can you also verify these values to be correnct and give me the missing values or at least point me in the right directions
Old 12-20-2006, 06:01 PM
default value:
Can be found on the unit itself ...check the manual for ID Number (SysEx).
filosofem
Midnam, Middev and SMF Files DNEW32 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-08-2011 09:33 AM
Midnam and Middev files Servon Pro Tools M-Powered (Win) 1 01-22-2010 10:59 AM
.midnam / .middev files harosha 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-09-2009 12:36 PM
Creating/Editing .middev and .midnam files in Windows harosha 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-31-2008 03:37 PM
midnam/middev xml files mdspike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-29-2004 09:20 AM
