Ideas Box ... Nesting Tracks ... Not just Fader Groups .. bring it!
wouldn't it be great or is it already possible (and i'm oblivious to the function )to "nest" tracks - not just or only fader groups
if we had a 6 track mono field recording - you find the balance between all the 6 mono trk that you like - assign all 6 mono trks to the same buss - that buss assigned to an aux master faded - then ... this is the good bit - those 7 tracks are highlighted a right click of the mouse - select "nest tracks" ... your 6trk sub mix now appears as a 1 track nested to 1 fader (like a VCA or aux master) - collapsing the 7 traks to 1 trk saving screen real-estate how good would that be!!! if later you find you need to tweek the sub mix - cmd+opt+n will reveal the original trks for you to tweak - then collapse to a nest if you like again whalla ... AM I DREAMING OR WHAT!!!! final cut pro had this feature in like version 2 ages ago ... picture editors collapsing multi track video to keep your time line easy to navigate / more efficient / less clutter and very manageable when you have over 128 traks in a session ... can this not be done in tools??? wheres the ideas box ... is there an ideas box??? HELP MEEEEEEEEEE! |
Re: Ideas Box ... Nesting Tracks ... Not just Fader Groups .. bring it!
No, you can't nest audio unfortunately.
But you could - if there's no automation involved - audiosuite each region/track and afterwards move the seperate mono tracks to a 5.1 track (if that's what the 6 tracks are for) Hope this helps, Timothy |
Why not just hide the 6 mono tracks?!
[email protected] Newcomer Audio Post MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock... Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock... |
To change the relative balance of the six tracks. Insert a multi-mono trim plugin and turn off the "link" button. You can now select the trim volume of each channel individually. And you can technically automate each trim as well, if you want/need to. |
ow do I assign groups to a fader in LE 7.4.2 | dbluprecords | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-06-2009 12:07 PM |
Groups (nesting groups) | whitetar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-18-2009 08:25 PM |
TRYING TO BRING TRACKS INTO MY AVALON 737. HELP!!! | PJJames | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-24-2007 08:59 PM |
fader groups or submasters in film mix | tomcat | Post - Surround - Video | 4 | 02-12-2005 06:16 PM |
Bring down master fader or group all faders? A test... | Corey Shay | Tips & Tricks | 9 | 12-28-2000 12:11 AM |
