Old 10-23-2004, 10:17 AM
detroitkruk detroitkruk is offline
Default PLEASE HELP!!! SESSION PENDING!!!
pro tools 5.x TDM will not load...fine yesterday...nothing today...
goes through the loading routine...stops 2/3 through the progress bar and says "PRO TOOLS HAS UNEXPECTEDLY QUIT, TYPE 2 ERROR"
rebooted, powered down...still nothing
PLEASE HELP IF ANYONE IS ON RIGHT NOW...CLIENTS WAITING...
detroitkruk
The Used Stars
Old 10-23-2004, 10:22 AM
kcurry kcurry is offline
Default Re: PLEASE HELP!!! SESSION PENDING!!!
You could try deleting preference files for PT and DAE...
Old 10-23-2004, 10:33 AM
SimpleNatureSpirit SimpleNatureSpirit is offline
reload/repair PT?
Share the gift gifted to you
Old 10-23-2004, 10:36 AM
JC925602 JC925602 is offline
Try disk warrior, it may be a corrupted HD.
JC
Old 10-23-2004, 10:37 AM
how do i delete those...
where are the files/folders to delete...
THANK YOU!!!
The Used Stars
Old 10-23-2004, 10:58 AM
John McDaniel John McDaniel is offline
Open your System folder.
Look for a folder named "Preferences"
Inside the Preferences folder will be files named "DigiSetup" and a Folder named "DAE Prefs".
DELETE these (the DigiSetup file and the entire DAE Prefs folder).
A new DAE Prefs folder and DigiSetup file will be re-created. You'll have to go through Hardware Setup when you boot Pro Tools.
It doesn't hurt to delte the Pro Tools preferences file either, just remember that you'll lose your pref settings in Pro Tools.
Reboot the Mac.
If you still have problems, try installing a new DAE from your Pro Tools software CD.
Inside the System folder is a folder named "DAE" and inside the DAE folder is the DAE.
Replace the DAE file, NOT the folder.
j mcd
go to the Digidesign answerbase ...
Old 10-23-2004, 11:12 AM
Avid's Avatar
Avid Avid is offline
Administrator
Don't forget to allocate more memory to both DAE and the Pro Tools application after you have installed fresh copies of both:
http://www.digidesign.com/compato/os9/mix/
If you are installing from your Pro Tools CD, you may be able to drag and drop DAE and Pro Tools, but make sure you are replacing the previous versions that may have been corrupted. If necessary, drag the old versions to the trash and empty trash first. But don't do that unless you have access to the replacement files on your Pro Tools CD.
If none of the suggestions given so far help, you need to give a lot more of your system details, including hardware, software versions and settings.
Administrator
new build pending Bim 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 09-05-2010 07:25 AM
Delivery receives but still pending? Frank Kruse Aspera DigiDelivery 0 11-19-2007 11:47 PM
7.3 pending????? surroundworks Pro Tools TDM Systems (Mac) 4 12-06-2006 11:02 AM
LT Pending Delivery Limits David McRell Aspera DigiDelivery 6 01-11-2006 12:56 PM
MIDI interface, pending OSX davidp158 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-02-2002 02:27 PM
