Quick (Simple?) Exporting Question
Hey All,
So I learned me a new trick last night. How to export my session into WAV files. Doing that so I can have the ability to send WAV files to someone else who might not have the same DAW or same Plug-Ins as I. One thing I noticed, is I had 2 rhythm guitar tracks one panned 100% to the right and 1 panned 100% to the left. When I exported everything out as WAV files and went back and listened to a few of the WAV files, I noticed my two rhythm guitar tracks were balanced. Does Pro Tools center the audio when in exports to WAV files like that? And I was using Multiple Mono for the Format.. Thanks..
Edward Fenley "Either learn to endure, or hire a bodyguard." ~ Bruce Lee |
Re: Quick (Simple?) Exporting Question
No.
But it is unclear how you are exporting your session into WAV files. There are multiple ways. You might want to specify which one you are using (which menu option.) And most importantly, it will depend on your output selected (whether physical output or bus) for the export. Panning and level are applied after the audio track. If you want to make them part of the track, you have to export from a point in the signal chain after the audio track.
Pro Tools Ult 2024.3, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire HD10 + Max11, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.5 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
I believe he means "Export Clips as Files" command from the Clip List. All this does is export the raw audio using the name of the Clip. Nothing that is not in the Clip is included. No automation, no real-time effects. If you want that, you have to bounce the audio out.
Indeed, there are several ways to get wave files out to any other DAW, so its well worth learning about the different options. You found #1, which exports raw audio files with no other info.(hope you remembered to consolidate all back to zero so they all line up when imported to another system). Bouncing tracks is another option and works great for creating "stems"(sub-mixes of similar tracks like BGV's or drums if you already have a great mix). The next great option is Track Commit. That can be done at the "end" of a track's processing(plugins, pan and volume automation), or it can be done at any stage within the track(say you have 5 plugins and the first 2 are exactly what you want, you can choose Commit up to This Insert and "render" the first 2 plugins, but skip the rest so the next engineer can not be "stuck" with all of your processing. Each has benefits and drawbacks, according to your needs
When I get time I’ll do a quick video of what I did.. thanks for the input guys!
PT Learner here - Very quick simple help please | CottersJ | Pro Tools 9 | 4 | 12-12-2010 10:52 AM |
Simple Exporting to movie question?! thanks!!! | Dan M. | Post - Surround - Video | 3 | 03-04-2005 08:57 AM |
need quick answer for simple question | richsorr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-16-2004 07:14 PM |
Quick Simple Question | tonebeats | Tips & Tricks | 2 | 03-04-2004 11:53 PM |
Need quick help on exporting to MP3 | Joseph Anderson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-10-2002 04:08 PM |
