Rough mix to stand alone cd burner ?
Hey guys I'am trying to send a s/pdif output signal from a Master fader to the s/pdif in of a tascam
cdrw 2000 .I'am using a 002r with protools 7 I can't get no signal at all any one Thanks jack
Mac Pro 8 core Protools 10 HD 4 Accel PCI with Magma, C/24 with 2 192 I/O Isochrone clock |
Re: Rough mix to stand alone cd burner ?
Have you bussed the master fader to the spdif output? Create a mater fader and check the output config.
Cheers, Scott
"...I asked you not to tell me that!" |
hey Scott I'am a newbie, so how do i do that,and can you explain
hey scott when I create a stereo master fader and go the bus there is no s/pdif option
BUS 1&2 stereo Bus 3&4 stereo and so on I've tried to select the s/pdif output of the master fader with no luck
Go to your I/O setup window and check to see if SPDIF is setup as an output. If not, go ahead and use ADD PATH and assign it. Setting the I/O to DEFAULT may also work.
hey albee I went into i/o setup at the right hand bottom there is three options
analog 12 stereo So in the new path set it to stereo analog 34 stereo analog 56 stereo analog 78 stereo adat 12 stereo adat 34 stereo adat 56 stereo adat 78 stereo s/pdif Stereo control meter path audition paths: New Track default
Computer Burner or Stand alone | Punx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-16-2003 10:16 AM |
Critique my rough mix please! | nmartin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-26-2003 08:49 AM |
001 rough mix--Feedback anyone? | SAMP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-28-2003 10:18 AM |
using a stand alone cd burner with pro tools? | jacko32 | General Discussion | 11 | 04-10-2002 01:43 AM |
Wave Burner-Type software for Lacie Burner? | Loftman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-04-2002 11:08 AM |
