Re: Chossing an iMac 27" - Which one?
And the old avoid i5 is years ago. The new i5 is plenty more powerful and a higher spec i5 is what I would go for and the money saved from i9 i would put towards RAM and SSD drive and an External Thunderbolt SSD Drive for recording and that iMac would be a GREAT option for many years to come.
Wow, then a cheap approach isn't really an option for me. How come i5 is something to avoid? And I just saw at Apple's store iMac with i7. Did you mean it no longer available for Pro Tools? And from your experience, how much difference is there between the latest iMac to, let's say, 2017 iMac? Or even 2015? Thanks in advance:) |
What about i7? Do you think it's worth the money or maybe i5 is enough? And which factors are for you the most important for working with Pro Tools? RAM? SSD? Processor? Which one of them has more influence on performance? Thanks in advance :) |
I would say all of them so if you want a solid iMac get an i5 with Big SSD drive and minimum 32 GB RAM and 64 GB if possible as those along with an i5 will be more than enough. The newer i5 processors are not the same as the older ones where everyone suggestdd going i7 so yes if you fknd an iMac i7 with lots of ram and big SSD drive (high spec) then Yes but if it is a big price difference get as high specd as possible and an i5 iMac and you will be set for a long time. With cash for an external Thunderbolt SSD drive for recording to aswell. My opinion of course and we have used Mac Pros for 15 years so I wanna think we learned something along the way what is worth putting money into and what is overkill and where to go all out to get the best option.
What about the GHz for the processor? any real difference between 3.1 to 3.6? |
Go to everymac.com and check the specs, they are all there
I mean from your experience. Like how much impact did you feel there was between 3.0GHz to 3.7GHz
As I said, GHz tells you nothing. Go there and see the geekbench score. Those you can compare
You save money and can put that towards more specd RAM and extra SSD drive.
What is your actual current and likely future working computer load/ needs . Music only, or music and video ? How many tracks total normally .... How many audio tracks.... How many virtual instrument/midi tracks et..... And what is a realistic budget range you can comfortably spend ? All of this specific info will give a more accurate picture for getting more targeted suggestions.
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
Getting a lot of "Hardware buffer underflowed (-6085)" messages w/new(er) iMac | Shanegrla | macOS | 1 | 12-23-2011 10:00 AM |
iMac PT LE 7.3cs1 Rack 003 Error "Not Installed or Used by Another program" | gcharles | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 12-01-2010 08:24 PM |
New 27" imac / "original" mbox - need some clear advice.please help !! | santococo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-21-2010 10:30 AM |
Can't open PT on new Imac -- "Required software extensions are missing" | jsbeeth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-21-2009 07:27 AM |
CHOSSING THE RIGHT SCHOOL:SAE OR PROTOOLSTRAINING | alion | General Discussion | 19 | 05-03-2005 12:22 PM |
