Old 06-11-2002, 05:31 PM
aurelio funk dias aurelio funk dias is offline
Default "STEREO" Mono Pair
Yesterday a received a dialog (10 Ch) to edit,clean up.
That's a PAIR of MONO TRACK. Can I use just ONE channel, because they are MONO.
Some advice will be good.
Thanks
Funk Dias
www.myspace.com/aureliodias
Old 06-12-2002, 09:00 PM
Richard Fairbanks Richard Fairbanks is offline
Default Re: "STEREO" Mono Pair
Mono is mono, whether its on one track or twenty. Try this, take your two "mono" tracks, play them through the same monitor path but flip the phase on one od the tracks. If you can balance the gain between the two tracks so that the sound output cancels (to silence) then you do truly have mono on both tracks, and it is safe to make the second mono track inactive and hide it. I wouldn't throw it away just in case you discover a problem with the first track.
Call me by my real name, "Postman"
Old 06-13-2002, 08:27 AM
Thanks Richard.
HTML code is On
Consolidate vs Duplicate - "Stereo" vs. Dual Mono Behaviour rnd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-05-2013 01:03 AM
What are the difference between using a "mono" vs "mono/stereo" plug in on mono track rockguitarist1255 Pro Tools 10 4 12-07-2012 08:07 AM
Mono, but no "Beatle Stereo" Moses Presley Tips & Tricks 18 09-22-2003 02:51 PM
HOW can you import a "stereo" WAV. file into PT as a "mono" file? peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-21-2002 09:14 PM
What do i import a "dual mono" audio file as??? mono or split stereo? peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-17-2002 04:02 AM
