Old 04-14-2021, 06:39 AM
diogomusique diogomusique is offline
Default Re: PT Hangs/Freezes at end of bounce, must force quit
Solved!
Thanks!
Originally Posted by nebosphere View Post
Anyone try bouncing with the pad to frame boundary box checked? If my session happens to be crashing after a bounce, unchecking that box usually fixes it. I would never check it manually - seems pro tools leaves it checked if you had previously bounced an mov and then do another bounce as another audio format (in this case wav).
Old 04-14-2021, 10:19 AM
nebosphere nebosphere is offline
Great! Still a bug tho!
Old 04-15-2021, 10:58 AM
marmotman's Avatar
marmotman marmotman is offline
Was happening on my Win 10 machine earlier. Thought it was maybe Pad to Frame but turns out it was Parallel Task Optimizations. Turned it off, everything back to normal.
Drink up, dreamers... you're running dry
Old 04-23-2021, 03:14 AM
hobphin hobphin is offline
I'm getting this issue, but only on video bounces, in any format
I've opened a tech support case several days ago and heard nothing :-(
case number 04159091
I really need this fixed as I should be bouncing post rushes all day long!
Old 04-23-2021, 03:22 AM
How would I turn the Parallel Task Optimisations off please?
  #16
Old 04-23-2021, 11:31 AM
Are you bouncing to the exact length of the video? And What format is said video?
  #17
Old 05-30-2021, 12:44 PM
MobiusTrip MobiusTrip is offline
Those of you experiencing this issue:
  1. Are you using Bars/Beats for your grid?
  2. Do you have the Conductor enabled?
  3. If so, what is your tempo?
I'm experiencing this issue when my session is set to an odd-numbered tempo (99, 101 BPM), or any decimal value. I removed all plug-ins from the Plug-ins folder, had only Maxim on the mix bus, and any attempt to bounce ends with a SWOD / hang at 0:00. My .wav files are corrupt, however. I can either disable MAXIM, or set my tempo to an even number / no decimal (100, 98, etc), or disable the Conductor.
This is a brand new session with only a click track and an aux mix buss, latest release of Pro Tools.
  #18
Old 06-22-2021, 10:28 AM
jmercel jmercel is offline
I was also experiencing this issue with ONE session in particular (other sessions bounce to .wav, .mov, etc. w/no issues) so I thought it might be plug-in related... BUT, looking closer at the session, I noticed that although the beginning and end points of my bounce were on the bars/beats grid I was actually starting/ending in between frames on the timecode grid (I'm working on a film project). After moving my start/end markers onto a frame, it bounces with no issues. I would have thought the pad to frame boundary checkbox would handle this, but apparently not? Give it a try if it's still giving you issues.
  #19
Old 06-22-2021, 11:41 AM
Its in Preferences
ProTools Quit Grayed out, can only force Quit real_eyes Pro Tools 2018 6 02-26-2019 06:29 AM
Force quit Next Pro Tools | Intro Discussion 1 08-28-2016 05:44 PM
Pro Tools refuses to quit. Have to force quit. SD2 Pro Tools 10 13 01-23-2014 08:21 AM
The following incident with Altiverb will force me Force Quit PT 25ghosts Pro Tools TDM Systems (Mac) 0 03-02-2009 01:30 PM
Pro Tools must force quit to quit losttimestudios Pro Tools TDM Systems (Mac) 3 03-21-2005 09:32 AM
