Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
  #101
Old 10-05-2018, 06:53 AM
Ken Skoglund Ken Skoglund is offline
Default Re: ProTools 2018.4 Ultimate and macOS Mojave
I have not read all 10 pages of this, only the first 3-4, but if anyone needs a High Sierra installer, I have a 10.13.02 installer, that one and Install Disk Creator makes a USB drive an install disk. PM or e-mail me.
  #102
Old 10-05-2018, 07:12 AM
~ufo~ ~ufo~ is offline
I seem to remember it's generally considered that most people start hearing something as a delay after 12ms.
That said, I've tested this and there's definitely a grey area where my brain, when presented with the direct and delayed signal, will start to identify something as smearing by duplicates and it's around the 4ms mark. It's not clearly identifiable as an echo, but it is definitely fuzzy and not crisp.
Which is one of the reasons why I try to keep my latency under 4ms if I can.
Now, if you are not presented with the original (direct sound) and only hear the delayed version (like is the case with a guitar amp), I think it's maybe less distracting for us.
Yes we can adjust. Still, Sub 4ms rtl is preferred over super 4ms rtl, whether it's doable or often done in 4-12ms or not. quicker is nicer.
Also, the point is that HD Native offered this, is advertised as such and hasn't been stably performing like that for years now, where it did before.
Regardless of whether some of you think it's NECESSARY to record with such buffers, the fact remains that on my two systems, PT has been generally deteriorating in stability ever since PT11, no matter whether I'm recording at low buffer, producing at medium buffer or mixing at high buffer. Granted, I've more problems at low buffer than at high buffers, but it's definitely far from rock solid at high buffers.
PT has been consistently performing worse than PT10 for me, and since the PT11 revolution started half a decade ago, I'm frankly losing my patience over its growing pains.
Are you all happy campers?
  #103
Old 10-05-2018, 07:47 AM
JFreak's Avatar
JFreak JFreak is offline
Originally Posted by Ken Skoglund View Post
I have not read all 10 pages of this, only the first 3-4.
Yea please folks (myself included) please keep on topic and find an old thread for latency talk
Janne
  #104
Old 10-05-2018, 07:56 AM
Yes, so I'm particularly interested in how you other people have experienced the stability of PT since PT11.
- Recording at low buffers
- Producing at medium buffers
- Mixing at high buffers
Are any of you on 3.33 GHZ 6-cores? What are your experiences? Has anyone tried Mojave?
Does it seem like an improvement over HS?
Are any of you on 3.46 12-cores? What are your experiences? Has anyone tried Mojave?
Thanks.
  #105
Old 10-05-2018, 08:33 AM
DetroitT's Avatar
DetroitT DetroitT is online now
Thanks.
Both HS and Mojave have been very non crashy solid. Using amd mac edition video 7950.
Os 10.14 ive been able to work hdx at 64 buffer but eventually error.
In HS i could not
128 buffer several hours with VIs then a popup error.
256 all day no errors. Hdx has never been this solid.
Loadup from drives (ssd or spinners) seems slower.
But. I like solid working.
Sig is my test system im commenting on.
(Help us Help You)<<<click here
Testing:All APFS 90% 10% Audio on HFS+(Testing 1.5 yr in)
Pro Tools U-2019.6 MacOS 10.14.6
Second boot-10.13.6 (Avid HDX-1 Omni)
(MP 5,1 / 64-Gb)
(Sapphire RX-580 MacVCEdition, 3-Displays)
MOTU FW-CoreAudio (for poly recording)
(SSL-HUI-MIDI over IP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
  #106
Old 10-05-2018, 01:12 PM
Interesting, Thanks!
What’s the processor in your 5,1?
  #107
Old 10-05-2018, 03:04 PM
KV626's Avatar
KV626 KV626 is offline
Thanks.
I'm on a newly upgraded 2x3.3 12 cores (originally 2x2.4), Mojave is rock-solid. And I have to say Pro Tools as well (2018.7). A very pleasing experience so far. I mix at 1024 and otherwise work almost exclusively at 128 - I mostly use VIs. No problem, no errors, no crash.
Mac Pro 5,1 (Mid-2012) 12-core 2 x 3.3 GHz / MSI RX 560 / 40GB ram / macOS 10.14.5 / Pro Tools 2019.5 / Logic Pro X 10.4.4
Arturia Keylab 88 Presonus Faderport 8 MOTU 896 iPad Air 2 w/ PT Control
NI Komplete Ultimate 11 • Albion One • Soundiron Choirs • Pianoteq • Analog Lab • VSL SE/Chamber Strings • etc
  #108
Old 10-05-2018, 04:28 PM
xps4000 xps4000 is offline
I updated to Mojave and then upgraded to PT2018 and now I crash on clips I want to edit and channel I attempt to move. Totally forgot to read the fine print (apple). Now after tracking a bunch of material I have to bump down to PT10 and work as I cant see on taking more down time to downgrade back to Sierra. Bummer. NEWB
  #109
Old 10-05-2018, 04:46 PM
JFreak's Avatar
Yep, PT isn't supported on Mojave yet so your mileage may vary...
Janne
  #110
Old 10-05-2018, 06:00 PM
Cacov's Avatar
Cacov Cacov is offline
I do! PMd you. Tnx !
macOS High Sierra | Apogee Groove & Symphony I/O | Pro Tools 2018
Non-Avid Employee | Sound Engineer
macOS 10.13.6 with 2018.4 SigFriedChicken macOS 8 07-26-2018 02:39 AM
PT 2018.4 Ultimate bugs ? Glazik Pro Tools 2018 26 07-10-2018 11:56 PM
Protools Ultimate 2018 quits unexpectedly cristtiah Pro Tools 2018 3 06-26-2018 02:25 PM
macOS 10.14 Mojave and “cheese grater” Mac Pros jsbach Pro Tools 2018 37 06-17-2018 01:50 AM
S6 M10 v3.5 works with PT ultimate 2018.4 ? vudoo Pro Tools | S6 3 05-30-2018 03:06 PM
