Old 10-18-2016, 12:25 PM
mps mps is offline
Default Question re Dithered Mixer in ProTools HD
If I switch from the default mixer to the dithered mixer, do I lose existing mix parameters (pan, eq, level, plug-ins, etc)?
Old 10-18-2016, 12:37 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
Default Re: Question re Dithered Mixer in ProTools HD
As far as I understand the total number of plug-in instances is reduced but not functionality.
It only is used by PTHD 10 and earlier. If you are running a native, HDX or version later than 10 it does nothing.
Bob's room 615 562-4346
Georgetown Masters 615 254-3233
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 10-19-2016, 05:55 AM
mps mps is offline
To clarify what I'm asking:
Suppose I have an existing ProTools session using the default mixer and I've already mixed. The session contains settings for levels, pans, plug-ins etc. If I now switch to the dithered mixer, do I lose those settings and have to mix all over again? Or do the settings stay where they are?
Old 10-19-2016, 06:08 AM
JFreak's Avatar
JFreak JFreak is offline
Welcome to the forum.
No, you won't lose anything. Please do yourself a favor and google what dithering means. As far as PT is concerned, it was the trick that made TDM mixer sound "not so digital".
Janne
Old 10-19-2016, 06:13 AM
dtmprod dtmprod is offline
I run dithered mixer all the time, don't see any diff as far as automation, levels, etc. Like previous poster mentioned, its takes a bit more DSP, so if you're pushing your system to the max, you might see a few plugins saying there's not enough DSP available.
To be on the safe side, make copy of the session & try it on that. That way you're not doing any possible changes/harm to the original session. You might find that things sound a bit differently with dither, so who knows, you might end up making some subtle changes to compensate. Then you can compare & see what you prefer.
Old 10-19-2016, 06:15 AM
I've asked mastering clients to re-bounce using the dithered mixer and there were no problems with the settings changing in Pro Tools HD 7. I don't know about later versions but I can't imaging them allowing it to change.
Interview
Old 10-19-2016, 08:51 AM
you can switch freely between them.
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 10-19-2016, 10:58 AM
mps mps is offline
Thanks everyone! Just wanted to make sure there'd be no surprises.
Is the HDX Mixer Dithered? Trailerman Pro Tools HDX & HD Native Systems (Mac) 4 08-29-2012 03:14 AM
Stereo dithered mixer with summing mixer? Brahamnesik Pro Tools TDM Systems (Mac) 4 04-16-2011 10:13 AM
Question about dithered mixer Guy Staley Pro Tools TDM Systems (Mac) 6 09-30-2002 05:51 PM
5.1.1 dithered mixer question CLee Pro Tools TDM Systems (Mac) 1 03-29-2002 08:55 AM
Does PT5.1 have a dithered mixer? D E K Pro Tools TDM Systems (Mac) 0 03-25-2001 09:10 AM
