Old 06-22-2022, 09:36 AM
Will Russell's Avatar
Will Russell Will Russell is offline
Default D-Command not seen on Mac Studio ethernet port
I have a new Mac Studio running Monterey and PT 2022.5. I am unable to get my D-Command to be seen by the computer/PT when connected to the built in ethernet port.
I can get it to work with a USB-ethernet adapter. Anyone else with this problem?
When the D-Command is connected to the built in port the Mac reports "cable unplugged"
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Old 06-23-2022, 03:20 PM
Led Led is offline
Default Re: D-Command not seen on Mac Studio ethernet port
Have you got the correct ethernet connection chosen in the ethernet drop down in peripherals?
There was also this post, it's about PT12 but might apply..
https://duc.avid.com/showthread.php?t=378169
Old 07-30-2022, 03:31 AM
francois's Avatar
francois francois is offline
I think you need a reverse ethernet cable if you only use the main 8 faders D-command
PT 2023-12 ultimate -HDX1- OSX 13.6.1- MacPro 7.1
- D-command 24- Trinnov Dmon6
Old 07-30-2022, 05:45 AM
The Mac has auto connection switching like every other modern computer so that should not be the issue.
The issue will be the Mac Studio does not support the reaaaalllyyyy old 10base-T Ethernet that the D-Command uses. It's not uncommon for modern 10Gbit Ethernet to not support 10Mbit/10Base-T, and the Mac Studios sure don't.
You can get an Ethernet switch that talks to the Studio and also provides support for 10Mbit/10base-T devices, if it's a switch with 10Gbit support you'll might only have 10Base-T support if the switch provides a set of slower ports as well as some faster 10Gbit up/down link ports. Or get a separate 1Gbit Thunderbolt Ethernet adapter dongle or a Thunderbolt dock with a 1 Gbps Ethernet in it... but just check they also support 10Base-T. Either way be absolutely sure what you are buying has 10Base-T compatibility.
MTRX Studio with Dante on the secondary Ethernet port on an unmanaged switch? polyh3dron Pro Tools | MTRX & MTRX Studio 21 07-27-2021 09:07 PM
Artist Mix bad ethernet port? LandtBand Artist Series 4 08-07-2020 08:16 PM
Ethernet port 2 Frank Kruse Artist Series 23 11-05-2017 02:43 PM
Using other ethernet port for internet Stereo Missile Avid S4/S6 12 07-31-2015 08:51 AM
C24 Ethernet port quit.. please help! Surth ICON & C|24 1 07-22-2006 04:34 PM
