Old 11-04-2021, 08:00 AM
arche3's Avatar
arche3 arche3 is offline
Default Do u guys turn off the icons ever?
Can I just leave my d control on 24x7?
Sent from my SM-G986U using Tapatalk
Old 11-04-2021, 03:18 PM
BScout BScout is offline
Default Re: Do u guys turn off the icons ever?
We left our D-Command and D-Controls on all the time. They are now gone (we've moved to S6 for the big studios.)
However, in hindsight, I would probably not leave the D-Command and D-Control on. They have a multitude of power supplies (doing this from memory but 3 in the D-Command main unit and 1 in the extra fader pack. A similar count in the D-Control.) Ours ended up lasting longer than most (according to Avid techs they usually lasted a max of 5 years -- we got like 8-10 years) but they eventually need to get replaced (technically rebuilt -- have to replace some capacitors that expand eventually) and it is kind of a PITA.
Probably could have extended the life even further if we had switched them off more often. The other thing is when the ICONS are powered, the faders (touch-sensitive) have more of a chance of getting damaged. We had to replace a few fader banks over time because of stray/static electricity zapping those faders. At some point, Avid switched to a different fader version that were more resistant from that kind of damage. So you might have the better faders depending on what version you have (none of the original "blue" Icons had the good faders but if fader banks were switched for repair, they might have ended up getting the good faders as a hardware replacement)
Old 11-04-2021, 04:20 PM
arche3's Avatar
Thanks for the insight. I'm gonna keep turning off.
Old 11-05-2021, 03:33 AM
Will Russell's Avatar
Will Russell Will Russell is offline
My D-Command gets turned off every night.
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Old 12-02-2021, 08:17 AM
francois's Avatar
francois francois is offline
same here ,I use to keep it on and got power supply problems when repowering after a studio updating/cleaning
PT 2023-12 ultimate -HDX1- OSX 13.6.1- MacPro 7.1
- D-command 24- Trinnov Dmon6
icons Macsearcher Artist Series 0 03-20-2015 03:41 PM
Can't turn off Mac Function keys/turn on PTLE Shortcut keys b mcgibney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 09-25-2009 09:15 PM
to turn off 002 or not to turn off 002? that is the question andy1908 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-07-2007 10:47 AM
ok guys, I got drum kits from hell, how do you guys use them? compblue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-29-2003 05:58 AM
