Multitool cursor virtually invisible in midi tracks
I’m venting this again because it is my single biggest criticism and source of frustration in ProTools, spend most of the time looking for the cursor than composing music
Brian Hudson |
Re: Multitool cursor virtually invisible in midi tracks
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Can you be more specific on the solution Sent from my iPhone using Tapatalk
Brian Hudson |
Found this using my clients 24" iMac. Loose the cursor in PT which certainly isn't the best situation. I never found this on the 27" iMac with the older OS so I think it is maybe OS/settings specific? Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2 https://www.waves.com/r/djgsi6 |
Thing is no one can be more specific because you give zero system information. That's the point behind the 'help us to help you' reference.
I know this to be an application problem not a system issue hence I did not provide specific hardware platform or software version info it’s quite simple the cursor is not visible easily I’ll try another route Sent from my iPhone using Tapatalk
Brian Hudson |
Plenty of people put their system info in either their sig file or on their profile page. There's no such thing as a generic answer to problems. Try another route - fine but don't expect to get an answer with the same amount of info you've given us |
Same here once a while - old PT bug.
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 |
Thanks anyway Sent from my iPhone using Tapatalk
Brian Hudson |
Here’s a visual example of the multitool cursor when editing in a midi track it seriously has got nothing to do with my ProTools version, operating system or hardware interface try finding that cursor when your creative juice is flowing Sent from my iPhone using Tapatalk
Brian Hudson |
cursor invisible on edit screen over tracks | blankpro | Pro Tools 2018 | 1 | 04-08-2018 06:34 PM |
Pts 12.5 multitool bug | jayrauscher | macOS | 1 | 06-16-2017 03:15 AM |
Virtually impossible - MIDI Mysteries solved for US$10 | unkJE | Virtual Instruments | 0 | 08-05-2014 02:53 PM |
Update: missing, invisible, disappearing tracks in Edit Window only, please help! | waswillbe | Pro Tools TDM Systems (Mac) | 5 | 01-17-2011 11:36 AM |
PT 8 - MultiTool | jmdeno | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 04-13-2009 11:58 AM |
