Offset after recording audio routed thru a bus
today I recorded some background vocals. Same Setup as always (since years): 2 Mics using two preamps. The 2 outputs of the preamps are connected to Input 1 & Input 2 of my HD i/o. The two Inputs of the HD i/o are set as input sources of two AuxInputs within PT. The Outputs of the 2 AuxInputs are routed via one mono bus to an audio track so that I can record the two mics as one MonoAudioTrack. After recording I remarked that the recorded AudioClip had an awful offset (much too late). I tried all kind of trouble shooting, like disabling and re-enabling ADC, changed playback buffer size, disabled dozens of PlugIns ... but no success. All I could do was to record directly to an AudioTrack without the routing via a bus . Of course I had to use 2 AudioTracks, each set to a different input as I was using 2 preamps plugged into my HD i/o. Any idea what could have happened and have others seen this, too ?
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 |
Re: Offset after recording audio routed thru a bus
no - this was of course the first thing I checked - just clean AuxInputs without any PlugIns. The AudioTracks also had no PlugIns. Is it that what you meant with "master track" ? Thx
john
Yes - there was no Plugin in the Master Out1-2. You cannot record if there is an active PlugIn - too much delay during recording (i.e. Ozone or Alchemist).
no one else seen this ?
post the session.
Hi Drew,
would be great if you could look into into it ! The AuxInputTracks tracks for the 2 PreAmpInputs are on track number 20 and 21. https://www.dropbox.com/s/7lwhbqpm42...m.ptx.zip?dl=0
sorry, had out of town clients with me all weekend, will check today.
EDIT-I'd start by making the Mac Input inactive. |
No - this isn't it. The MacInput is active in my session. However, even if I delete the StereoAuxInput for the MacInput, the offset remains.
I did an hour testing today. As as I route a "live input" thru a bus into an AudioTrack I'm getting an offset. Even in my session template. If I disable ADC then it works ... but then of course all the rest of the tracks aren't in sync anymore Any other idea (beside a complete new MacOs from scratch installation) ?
Routed audio into Pro Tools w/ Soundflower | lincol1 | macOS | 14 | 04-19-2012 10:34 PM |
having pc audio routed to mbox2 and out of monitors | liannino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-09-2011 06:15 PM |
Audio not routed properly | Pais_man | macOS | 2 | 02-25-2011 05:31 PM |
does Video offset cause audio recording delay? | compusic | Post - Surround - Video | 34 | 05-25-2010 08:26 AM |
Internal Audio vs PT8 routed? | thopman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-27-2009 05:24 AM |
