  #101
Old 06-22-2013, 08:41 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Pro Tools 10 XPAND2 No Sounds?
Originally Posted by samth3mancgp View Post
Sooo... I installed ProTools 11 today and GUESS WHAT!
SAME Problem, none of the AIR instruments can find their factory content. I have literally no idea what to do.
Wish that somebody from AVID could help me figure out whats up.. but I'm not holding my breath..
U got a ASC support code use it
Daniel
  #102
Old 07-03-2013, 08:47 PM
glennaudio glennaudio is offline
Another bump for this issue on Mac OS X 10.8.3/10.8.4, Pro Tools HD Native 10.3.6/11.
WTF AVID? I've been having this problem with xpand since Pro Tools 9!!!!!!!!!!!
For those who don't have a temporary workaround, I do the following:
1) control+command click on the XPand plug in to deactivate
2) control+command click on the XPand plug in to reactivate
3) repeat if necessary until prompted to locate the .big file again
4) plug in loads previously loaded patch/settings and still works
The problem is I hate having to do this every time I want to use the plug in or open a session that uses the plug in.
Pro Tools Carbon | HD Native 2021.12 | HD I/O 8x8x8 | UA 4-710D | Avalon VT737 | Waves Mercury | Komplete 13 Ultimate Collector's | Kontrol S61 | Maschine Studio | Eleven Rack | Pro Tools Control w/ 9.7" iPad Pro | Pro Tools Dock | S1 | MacPro 7,1: 16-core 96GB RAM W5700X GPU OS 11 1TB SSD +OWC 1m2 2TB SSD (samples) +Sonnet M.2 4x4 4x2TB Samsung Evo Plus SSDs in RAID 0 (sessions)
  #103
Old 07-12-2013, 10:16 AM
samth3mancgp samth3mancgp is offline
Yup your issue seems almost identical to mine..
Do you by any chance have your user account folder on a different drive than the OSX drive? I keep all those files separate from the boot drive since I use a small SSD for OSX.
I'm just curious if you do the same thing since maybe that could be related to the problem?
  #104
Old 07-27-2013, 01:40 AM
mickblah mickblah is offline
Hi all - ive just dealt with a special version of this problem.
Some college macs had developed "xpand aversion syndrome" on
upgrades to 10.3.3 and then this week on 10.3.6. These machines
have an admin and a student (nonadmin) accounts and the admin account
had no problems but the student account on some macs was looking in the wrong place and not remembering when i told it the right place.
My fix was to copy the contents of the admin xpand2.plist file into the
student xpand!.plist file that was in student prefs( note the weird exclamation mark) - keep the file name that auto created . Now they all
work and remember on reboot - if you havent got a working version of the plist file
you need to access the auto created plist file and replace the path and save the plist file - a note I used text wrangler as it shows all the file
contents but textedit should work for the path - I would start with an xpand prefs that installs with directions to creative instruments rather
than the blank one that appears after messing with it
my working path was "WContent_2/Applications/Avid/Avid Virtual Instruments/Xpand2"
this worked on all machines and lo and behold I then found an avid
link for an xpand! pref file app -
http://avid.force.com/pkb/articles/e...755&popup=true
Ive not tried this and have no intention of trying it now ive done the manual fix. It may very well just be a multiple user fix but as this is obviously a
sofware priviledges bug - telling xpand where its library is is a one off that you should need again - though keep a copy just in case! !!!!!!!!!
Note I did try all the reinstalls and moving files around without any luck first.
hope it helps somebody - i assume windows also has similar prefs but i wouldnt know where or how
mick
  #105
Old 07-27-2013, 04:49 PM
JCStarbright JCStarbright is offline
On Mac OSX this problem can be caused by moving the user account home directory. I solved this by creating 2 user accounts... MAC SOLUTION HERE:
http://duc.avid.com/showthread.php?t=342413
MacBook Pro 2.7 GHz i7 8GB RAM, Dual internal 512 SSDs, external 1TB SSD RAID. Universal Audio Apollo Quad, UA 4-710d tube preamp, Marshall JMP1, Eleven Rack, Roland GR-55 & GT-100. Pro Tools 10.3.6 * Listen to JCSTARBRIGHT on iTUNES!
  #106
Old 07-31-2013, 11:48 AM
I had a feeling that might be the issue.. but it looks like I won't be using Xpand for anything until that issue gets fixed and it can be used with the user folder on another drive. There's no way that isn't a simple fix. Everything else except Xpand works perfectly so whatever
I doubt it will ever be fixed! Who wants to bet on it
  #107
Old 08-03-2013, 07:01 PM
Andre_BR Andre_BR is offline
Having the same problem, no sound using xpand 2. Have already done everything suggested on olders posts, but no success so far.
Pro Tools 10.3.5
Eleven Rack
Axiom25
Dell XPS 8700, Core i7, 8GB
Windows 8 Pro
Path for xpand2.big: C:\Program Files (x86)\Avid\Avid Virtual Instruments\XPand2
Anyone can help me?
Thanks!
Andre
  #108
Old 08-17-2013, 10:30 PM
demodigi demodigi is offline
On Mac OSX.8.x, .plist files for Xpand2 MiniGrand and Boom aren't updated/written correctly.
I posted another option to sort this out (on Mac OSX) here (post 37)
(close to the solution mickblah posted but a bit more universal and prevent from creating an new user account as JCStarbright suggested).
Macbook Pro (Core2duo 2,4GHz RAM4GB SSD)
MacMini (Core i7 Quad@2,3GHz RAM16GB SSD)
PT 10.3.10 + PT12.4 / VEP5.3.1 / MacOSX.9.5 (MBP)
PT12.4 / VEP5.3.1 / MacOSX.11.1 (MBP)
PT 10.3.10 / PT11.3.2 / PT12.4 / VEP5.3.1 / MacOSX.8.5 (MM "Production" on SSD)
PT 12.4 / VEP5.3.1 / MacOSX.11.1 (MM "test" on HDD)
RME UFX (USB2 with MM and Firewire with MBP)
+ Vienna Ensemble Pro Server on PC Q6600/8Gb/Win7-Pro64-SP1
  #109
Old 09-18-2013, 05:21 AM
DaveBMusik DaveBMusik is offline
mick
I run a high school lab of 16 stations. Have had XPand issues for a year when we switched to Macs. I did a clean uninstall, reinstalled new MBox2 drivers, reinstalled ProTools 10.3 and installed Virtual Instruments. XPand2 worked on each station under administrative log-in. None worked under a students log-in. Through making tracks inactive (sometimes many times) or adding a new track, I was finally able to get to the "Browse for XPand2.big" file and was able to establish the link and get all machines to work. I'm not sure if we will need to do this every day or not.
Definitely a shame that this is a permissions / user account issue.
  #110
Old 09-19-2013, 09:01 AM
Hi DaveBMusik,
Did you try to edit Xpand preferences files (.plist) like I suggested in my previous link (toward my quite long post) ?
Certain XPand2 Sounds Missing MogDog Virtual Instruments 1 04-14-2013 04:37 PM
There are no sounds in xpand2 SEMMO Virtual Instruments 21 04-21-2012 06:16 PM
Are Xpand2 Sounds Available To Other Plug-Ins/Samplers? taylor4814 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-27-2009 09:21 AM
Favorite Xpand2 sounds. chrisdee Virtual Instruments 0 04-20-2009 03:33 PM
Sudden loss of sound while auditioning sounds in Xpand2 (Pro Tools 8) chrisdee Virtual Instruments 21 04-14-2009 12:54 AM
