bypass plugin?
Hey guys when I insert a plugin like eleven on a track, If i'am in record mode It goes into bypass mode and I can't take it out of bypass
mode while in record whats up
Mac Pro 8 core Protools 10 HD 4 Accel PCI with Magma, C/24 with 2 192 I/O Isochrone clock |
Re: bypass plugin?
If you're recording in PT LE in "low latency mode" some plug-ins must be disabled to enable recording. I don't know what the deal is in an HD system (I just tried it and I have the same issue) but I would assume it has something to do with it being an RTAS plug-in.
Dave CBS TV Distribution/On-Air PT 2019.6.0 S3 |
Re: bypass plugin?
They worked fine in Le. Its when I insert a plugin like Eleven, when I arm the track It will go in to bypass mode
Re: bypass plugin?
If so, place any TDM plug in before Eleven in the chain and it should work. I forget the science of why this works, but it does. Hope that helps! God Bless, David Glenn
David Glenn SpiritWalk Productions Azmyth Recording Studios http://www.myspace.com/davidglennjr |
Re: bypass plugin?
check out page 877 in the pt 8 manual
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4 32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE |
Re: bypass plugin?
Thanks Guy
All is going good This Hd system is all new to me so If I have any more ? hope you guys will help out Thanks Jack
ADC Bypass Plugin Errors | BobbyDazzler | Pro Tools 10 | 0 | 07-10-2012 08:52 PM |
Plugin Disable & Bypass | Soundtrack2life | Pro Tools TDM Systems (Mac) | 22 | 06-22-2010 04:10 PM |
Plugin bypass problem | Werner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-02-2008 10:17 AM |
Automate plugin bypass? | mixerboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-07-2005 10:50 AM |
bypass a plugin without charging CPU ? | saltine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-10-2003 08:57 AM |
