Mojo Video Sync Offset
Is there any way that Digi could put quarter frames in the Avid video offset? My new projector is 2.5 frames out and it would be nice to offet the video to the correct amount just like Quicktime movies.
Regards Paul McFadden Supervising Sound Editor Doctor Who www.bangpostproduction.com |
Re: Mojo Video Sync Offset
I wonder how this would work. If the Mojo is frame-locked to a blackburst, how can one trigger an image on a quater or halfframe and still lock to BB?
Did you measure your offset with syncheck using the line-cable? If not the .5 you´re seeing is probably because of the distance between you and the speakers in your room? In that case your only option is to delay the speakers to get 100% sync figures. frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
HI Frank yes I measured it with my Syncheck Box. What i'm currently doing is putting a 2 frame video offset then shifting my tracklay by 2 quarter frames. It's a dangerous way to do it. I think your idea pitting in a delay to the speakers is the best way.
Thanks for the advice as always Paul |
mojo is made to work with a avid file
if you can use a avid file you will have no sync problems if you are using quicktime files it looks better to convert them in quicktime to an avid codec but you still have a 14 quarter frame offset to fix the lag |
i dont understand the question. if it is the avid offset, you are using avid media so no offset there. The projector is adding a 2.5 frame delay then set avid offset to 10 quarter frames, right?
p.s. why are you answering a 3 year old thread?
Ken Wilkinson http://kenwilkinson.tv Pro Tools 10.3.9 HDN | HD Omni | Digi Command 8 | Artist Transport | Digi Surround Panner | Blackmagic Intensity Pro | JBL LSR4328 5.1 2.26GHz 8 Core Nehelam 8GB Ram OSX 10.8.5 |
Video Sync Offset using Mojo | SPC | Post - Surround - Video | 6 | 04-02-2011 11:46 AM |
Video sync offset | samplaire | Post - Surround - Video | 9 | 11-16-2010 05:50 AM |
Keeping Laybacks in Sync (delay compensation and Video sync offset) | edit machine | Pro Tools TDM Systems (Mac) | 6 | 11-15-2010 11:33 AM |
Video sync offset changes | Studio Studio | Pro Tools TDM Systems (Mac) | 0 | 09-15-2008 06:33 AM |
VIDEO SYNCH OFFSET (MOJO, SONY LCD) | Rick Sanchez | Post - Surround - Video | 7 | 05-24-2007 11:46 PM |
